주요 콘텐츠로 건너뛰기
1997-2003 Chevrolet Malibu Air Filter Replacement
필요한 것
  1. 1997-2003 Chevrolet Malibu Air Filter Replacement, Air Filter: 1 단계, 이미지 1/2 1997-2003 Chevrolet Malibu Air Filter Replacement, Air Filter: 1 단계, 이미지 2/2
    • The air filter housing is located on the driver side of the car.
    • Loosen the four housing screws on the plastic air intake box.
    • Do not try to remove these screws from the intake box, as they are not designed to be removed.
  2. 1997-2003 Chevrolet Malibu Air Filter Replacement: 2 단계, 이미지 1/2 1997-2003 Chevrolet Malibu Air Filter Replacement: 2 단계, 이미지 2/2
    • Loosen the hose-clamp on the air intake tube located on the side of the air intake box.
    • Remove the air intake tube from the intake box.
  3. 1997-2003 Chevrolet Malibu Air Filter Replacement: 3 단계, 이미지 1/1
    • Gently lift the top off of the air intake box.
  4. 1997-2003 Chevrolet Malibu Air Filter Replacement: 4 단계, 이미지 1/1
    • Remove the air filter from the housing and inspect it.
    • If it can not be cleaned, then it should be replaced with a new one.
결론
다른 4명이 해당 안내서를 완성하였습니다.
Sank Yang
회원 가입일: 10/03/12
484 평판
안내서 5개 작성하였습니다
Cal Poly, Team 9-15, Amido Fall 2012 Cal Poly, Team 9-15, Amido Fall 2012 회원
CPSU-AMIDO-F12S9G15
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 19
전체 시간: 5,470
