주요 콘텐츠로 건너뛰기
1997-2003 Chevrolet Malibu Fluid Check
필요한 것
  1. 1997-2003 Chevrolet Malibu Fluid Check, Brake Fluid: 1 단계, 이미지 1/3 1997-2003 Chevrolet Malibu Fluid Check, Brake Fluid: 1 단계, 이미지 2/3 1997-2003 Chevrolet Malibu Fluid Check, Brake Fluid: 1 단계, 이미지 3/3
    • Use caution while handling brake fluid. Brake fluid strips paint and dissolves plastic.
    • There is a maximum fluid line on the right side of the reservoir. Remove the brake fluid cap and fill the brake fluid to the maximum level line.
  2. 1997-2003 Chevrolet Malibu Fluid Check, Power Steering Fluid: 2 단계, 이미지 1/3 1997-2003 Chevrolet Malibu Fluid Check, Power Steering Fluid: 2 단계, 이미지 2/3 1997-2003 Chevrolet Malibu Fluid Check, Power Steering Fluid: 2 단계, 이미지 3/3
    • Do not overfill the power steering fluid reservoir, as this can overwork the power steering pump and cause it to burn up.
    • Remove the power steering fluid cap. Check the fluid level using the dipstick attached to the cap.
    • Fill the power steering fluid to the appropriate level indicated by the "H" for hot and the "C" for cold.
    • If the car has not been started then the fluid is cold. If the engine has been running for five minutes or more, then it is hot.
  3. 1997-2003 Chevrolet Malibu Fluid Check, Engine Oil: 3 단계, 이미지 1/3 1997-2003 Chevrolet Malibu Fluid Check, Engine Oil: 3 단계, 이미지 2/3 1997-2003 Chevrolet Malibu Fluid Check, Engine Oil: 3 단계, 이미지 3/3
    • Use the yellow handled oil dipstick to check the oil level by removing the dipstick, wiping off the oil, and re-inserting it.
    • Remove the dipstick again and check the oil level. Full level is read on the right side of the dipstick.
  4. 1997-2003 Chevrolet Malibu Fluid Check, Engine Oil Continued: 4 단계, 이미지 1/3 1997-2003 Chevrolet Malibu Fluid Check, Engine Oil Continued: 4 단계, 이미지 2/3 1997-2003 Chevrolet Malibu Fluid Check, Engine Oil Continued: 4 단계, 이미지 3/3
    • If the oil level is below full, add oil to the car by removing the cap labeled "Engine Oil."
    • Add a small amount of oil and repeat Step 3 until the oil level is full.
  5. 1997-2003 Chevrolet Malibu Fluid Check, Radiator Coolant Resrvoir: 5 단계, 이미지 1/3 1997-2003 Chevrolet Malibu Fluid Check, Radiator Coolant Resrvoir: 5 단계, 이미지 2/3 1997-2003 Chevrolet Malibu Fluid Check, Radiator Coolant Resrvoir: 5 단계, 이미지 3/3
    • Make sure the engine is cool before removing the radiator reservoir cap. Radiator coolant needs to be disposed of properly. Visit this link for more information http://www.epa.gov/osw/conserve/material...
    • Remove the radiator reservoir cap and fill it with coolant until it reaches the full level indicator line on the front side of the reservoir.
결론
다른 9명이 해당 안내서를 완성하였습니다.
Sank Yang
회원 가입일: 10/03/12
484 평판
안내서 5개 작성하였습니다
Cal Poly, Team 9-15, Amido Fall 2012 Cal Poly, Team 9-15, Amido Fall 2012 회원
CPSU-AMIDO-F12S9G15
4 회원들
안내서 5개 작성하였습니다
댓글 5개
GM does not want purchasers of used cars to check transmission fluid levels.
Hoping you run it dry so things blow up and you have to buy a new vehicle.
Beginning to dislike GMs
Randy Oman - 답글
I been trying to figure out why the cars shaking so i changed the spark plugs now it shake small kind now the airfilrt needs to be changed out as well but whats with the gas smell when turning on?
Bruce allen - 답글
I am trying to change my starter on my 1997 Malibu Chevrolet SD 2.1L but I am not sure if I can take it out from the top or it's best to go from the bottom? Need to know ASAP.
Renee Howington - 답글
I have a 99 Chevy Malibu what type of starter would work on my car
hernandezchina.1979 - 답글
Cómo saber el nivel de aceite de transmisión automática Malibú 99 que no está ala vista o como se checa gracias me urge
Javier Javy - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 35
30일 전: 139
전체 시간: 41,794
