소개
Replacing the spark plugs in your Malibu can keep it running strong. New spark plugs will produce a stronger spark than older spark plugs allowing your engine to run smoother and more efficient.
필요한 것
Use the 1/2" socket to loosen and remove the four bolts and washers on the spark plug cover labeled 2.4L Twin Cam.
거의 끝나갑니다!
To reassemble your device, follow Steps 1-3 in reverse order.
결론
다른 5명이 해당 안내서를 완성하였습니다.
