소개
It is not uncommon for a side view mirror to become detached with little impact. As such, knowing how to replace or reattach it at home can save you money. Beware any broken or protruding glass should the mirror you’re dealing with be broken.
필요한 것
Search for retaining screws holding the door handle bezel. If there aren't any, that's your clue that it snaps into place. There should be a small opening on the edge of the bezel.
Place the tip of a flathead screwdriver into the gap and gently pry, it should begin to come off, at which point simply slide it off of the handle.
Remove the window control panel just beneath the handle, it should snap into place just like the door bezel. Disconnect the wired connectors.
The connectors have a small pin that must be pushed in before they can detach, either use your fingers or a small Flathead screwdriver as shown in the pictures.
Similar to the door bezel and trim panels, use a flathead screwdriver and gently pry the panel off.
Now you should see a black material covering the door. This is called a vapor panel and protects the innards of the door form water and moisture. It should peel right off, but don't be afraid to use the screwdriver to gain leverage.
You will find another small connector similar to those found when disconnecting the window control panel. This operates the powered mirror and must be disconnected before the mirror is unscrewed.
Remove the small triangular portion of the vapor plate where the mirror mounts, you should see 3 large holes, inside which are the mounting screws for the mirror.
다른 2명이 해당 안내서를 완성하였습니다.
