주요 콘텐츠로 건너뛰기
1997-2001 Toyota Camry Headlight Bulb Replacement
필요한 것
  1. 1997-2001 Toyota Camry Headlight Bulb Replacement, Headlight Bulb: 1 단계, 이미지 1개 중 1개
    • Prop up your hood.
    • Make sure you prop your hood up with your hood prop rod.
  2. 1997-2001 Toyota Camry Headlight Bulb Replacement: 2 단계, 이미지 1개 중 1개
    • Locate the back of the headlight you plan to replace the bulb in.
    • This will be directly behind the headlight assembly.
    • If you are replacing your left headlight, you may need to remove the battery to have enough room to do this replacement.
  3. 1997-2001 Toyota Camry Headlight Bulb Replacement: 3 단계, 이미지 1개 중 1개
    • Disconnect the headlight.
  4. 1997-2001 Toyota Camry Headlight Bulb Replacement: 4 단계, 이미지 1개 중 1개
    • Remove the rubber cover by pulling on the tab marked "Pull Top" away from you.
  5. 1997-2001 Toyota Camry Headlight Bulb Replacement: 5 단계, 이미지 2개 중 1개 1997-2001 Toyota Camry Headlight Bulb Replacement: 5 단계, 이미지 2개 중 2개
    • Release the bulb by pushing the metal fastener inward and then moving it upwards.
  6. 1997-2001 Toyota Camry Headlight Bulb Replacement: 6 단계, 이미지 1개 중 1개
    • Remove the bulb.
  7. 1997-2001 Toyota Camry Headlight Bulb Replacement: 7 단계, 이미지 1개 중 1개
    • Insert the new bulb. Make sure the metal tabs fit correctly.
    • I've read that touching the glass on the bulb can shorten the life of the bulb, so try not to do that.
결론
To finish your headlight bulb replacement, follow these instructions in reverse order.
다른 16명이 해당 안내서를 완성하였습니다.
Chris Opperwall
회원 가입일: 04/04/13
1,394 평판
안내서 1개를 작성함
1가이드 댓글
The 2000 and 2001 Camry models take 9006 (HB4) bulbs for the low beams and 9005 (HB3) bulbs for the high beams, rather than the 9003 (HB2) linked here -- at least for the North American models I've looked up.
If you have the original owner's manual that came with the car, there's a table of all the bulb types you'll need for different lights in the "Do-It-Yourself Maintenance" section. It doesn't hurt to double check.
rakslice - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 8
지난 30일: 74
전체 시간: 50,420
