주요 콘텐츠로 건너뛰기
1997 Saturn II Passenger Side Mirror Replacement
필요한 것
  1. 1997 Saturn II Passenger Side Mirror Replacement, Passenger Side Mirror: 1 단계, 이미지 1/3 1997 Saturn II Passenger Side Mirror Replacement, Passenger Side Mirror: 1 단계, 이미지 2/3 1997 Saturn II Passenger Side Mirror Replacement, Passenger Side Mirror: 1 단계, 이미지 3/3
    • Pry the plastic panel away from the base of the side mirror with a metal spudger or your hands.
  2. 1997 Saturn II Passenger Side Mirror Replacement: 2 단계, 이미지 1/3 1997 Saturn II Passenger Side Mirror Replacement: 2 단계, 이미지 2/3 1997 Saturn II Passenger Side Mirror Replacement: 2 단계, 이미지 3/3
    • Remove the three 10 mm bolts using the 10 mm socket and ratchet extension.
    • If there is an existing side mirror attached, hold it to keep it from falling.
  3. 1997 Saturn II Passenger Side Mirror Replacement: 3 단계, 이미지 1/1
    • Remove the existing side mirror if there is one attached.
  4. 1997 Saturn II Passenger Side Mirror Replacement: 4 단계, 이미지 1/1
    • Mount the replacement passenger side mirror.
    • Ensure it lays flat with the car.
  5. 1997 Saturn II Passenger Side Mirror Replacement: 5 단계, 이미지 1/3 1997 Saturn II Passenger Side Mirror Replacement: 5 단계, 이미지 2/3 1997 Saturn II Passenger Side Mirror Replacement: 5 단계, 이미지 3/3
    • Hold the side mirror in the slot.
    • Tighten one 10 mm bolt as much as you can by hand first to keep the mirror in place, and then tighten the remaining two 10 mm bolts.
  6. 1997 Saturn II Passenger Side Mirror Replacement: 6 단계, 이미지 1/2 1997 Saturn II Passenger Side Mirror Replacement: 6 단계, 이미지 2/2
    • Replace the plastic panel by snapping it back on.
결승점
다른 한 분이 해당 안내서를 완성하였습니다.
Natalia Areno
회원 가입일: 01/11/21
133 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 17
전체 시간: 446
