주요 콘텐츠로 건너뛰기
1997 Toyota Camry Stop and Tail Light Bulbs Replacement
필요한 것
  1. 1997 Toyota Camry Stop and Tail Light Bulbs Replacement, Stop and Tail Light Bulbs: 1 단계, 이미지 1/3 1997 Toyota Camry Stop and Tail Light Bulbs Replacement, Stop and Tail Light Bulbs: 1 단계, 이미지 2/3 1997 Toyota Camry Stop and Tail Light Bulbs Replacement, Stop and Tail Light Bulbs: 1 단계, 이미지 3/3
    • Open the trunk.
    • Loosen three 15 mm screws using a Phillips #1 screwdriver.
    • Pull the cover clips at the base to remove.
    • Potential for device damage: Do not pull the cover clips prior to unscrewing as the cover clips can break.
    • Remove the cover by folding the cover backwards to expose the bulb assembly.
  2. 1997 Toyota Camry Stop and Tail Light Bulbs Replacement: 2 단계, 이미지 1/2 1997 Toyota Camry Stop and Tail Light Bulbs Replacement: 2 단계, 이미지 2/2
    • Grab the inner light bulb assembly using your thumb and forefinger.
    • Rotate the bulb assembly a quarter turn counterclockwise.
    • Pull it straight outwards until the bulb is displayed.
  3. 1997 Toyota Camry Stop and Tail Light Bulbs Replacement: 3 단계, 이미지 1/1
    • While holding the assembly, grab the base of the light bulb with your thumb and forefinger.
    • Pull the bulb away from the assembly until it detaches. Discard the old bulb.
  4. 1997 Toyota Camry Stop and Tail Light Bulbs Replacement: 4 단계, 이미지 1/1
    • Grab the new inner tail light bulb 3157 and push it into the bulb assembly.
    • Insert the bulb assembly straight into the socket. Rotate it a quarter turn clockwise to secure it.
  5. 1997 Toyota Camry Stop and Tail Light Bulbs Replacement: 5 단계, 이미지 1/1
    • Repeat this process with the outer light bulb assembly using bulb 904.
  6. 1997 Toyota Camry Stop and Tail Light Bulbs Replacement: 6 단계, 이미지 1/2 1997 Toyota Camry Stop and Tail Light Bulbs Replacement: 6 단계, 이미지 2/2
    • Unfold the cover and place it back over the bulb sockets. Push the three cover clips into their sockets .
    • Screw the three 15 mm screws in with Phillips #1 screwdriver to secure the cover.
결론
Your stop and tail lights have been properly replaced and your replace bulb indicator should be off on your dashboard.
Ivan Navas
회원 가입일: 02/24/21
138 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 6
7일 전: 17
30일 전: 66
전체 시간: 2,275
