이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Before disconnecting the spark plug wires, be sure to trace their orientation from the individual cylinders back to the distributor cap.
The cylinders are ordered from left to right when viewing the engine from the front of the car, with cylinder #1 being closest to the passenger side of the vehicle.
Disconnect the four spark plug wires from the distributor cap by pulling their connectors straight away from the sockets on the distributor cap.
Use a 1/4" drive, 8 mm deep socket to remove the three hex bolts securing the distributor cap to the engine.
Use a dental pick or a small screwdriver to gently remove the D-shaped o-ring around the distributor cap flange.
Install a new o-ring in the seal recess, making sure that it is sitting flush against the flange.
다른 13명이 해당 안내서를 완성하였습니다.
