주요 콘텐츠로 건너뛰기
1998-2002 Honda Accord Headlight Bulb Replacement
  1. 1998-2002 Honda Accord Headlight Bulb Replacement, Headlight Disconnect: 1 단계, 이미지 1/3 1998-2002 Honda Accord Headlight Bulb Replacement, Headlight Disconnect: 1 단계, 이미지 2/3 1998-2002 Honda Accord Headlight Bulb Replacement, Headlight Disconnect: 1 단계, 이미지 3/3
    • Pull on the hood release lever just inside the passenger door to pop the hood.
    • Locate the hood release latch under the hood. Use one hand to press up on the latch while you lift the hood.
    • Insert the hood prop rod into the hole in the hood marked with an arrow.
    Como puedo resolver que las luces permanentes traseras y la pizarra no encienden todas las demás prenden
    Yoan - 답글
    También se prenden solas todas las luces
    Yoan - 답글
  2. 1998-2002 Honda Accord Headlight Bulb Replacement: 2 단계, 이미지 1/2 1998-2002 Honda Accord Headlight Bulb Replacement: 2 단계, 이미지 2/2
    • Locate the head light bulbs and connectors directly behind the headlights and on either side of the engine bay.
    • Detach the head light connectors by pushing on the lever on the top of the connector and pulling it straight down.
    • If needed, you can disconnect the air intake (next to the battery) to get some extra wiggle room in order to detach the head light connector on the passenger side. If you remove the air intake, be sure to plug both sides with a clean, lint-free cloth so that nothing gets inside while you work.
    Sometimes the connector can be very tight and cannot be pulled off by hand, especially in such tight spot. One could push on alternate sides with a flat blade screwdriver gently to ease it off.
    atl7417 - 답글
    The passenger side low beam bulb was extremely difficult to remove, owing to very little space to work in. Then I realized that the air intake could be rotated and pulled out. It was easier than removing the battery. After that it was very simple. I found it easier to first unscrew the bulb assembly, and then detach the connectors.
    Thanks!
    Barry - 답글
    never seen or found a lever to push on top of connector, tho I do see it but it won’t pull of easy….a better picture or a close up and different description may help, I know to twist the back part of the bulb, I’ve done it before, but is giving me difficulty now, bulb won’t come out and harness won’t come off bulb either….very frustrating. 2002 accord
    kdubb51 - 답글
  3. 1998-2002 Honda Accord Headlight Bulb Replacement, Headlight Bulb: 3 단계, 이미지 1/2 1998-2002 Honda Accord Headlight Bulb Replacement, Headlight Bulb: 3 단계, 이미지 2/2
    • Turn the head light bulb counterclockwise and pull it straight back to remove it.
    E pisca? Não consigo
    Ricardo Fragoso - 답글
결론
다른 27명이 해당 안내서를 완성하였습니다.
Miroslav Djuric
158,241 평판
안내서 144개 작성하였습니다
댓글 13개
I change both bulbs and still high beam don't work what else can be wrong
stankopetek - 답글
Thanks Barry! It is really saved lot of time. Taking air take plastic tube is the trick. I was able replace passenger side head light bulb. Thanks
gc - 답글
This site has helped me soooo very much!! I can't thank you enough!!!!
Tina - 답글
Nobody can replace the headlight for my 1999 Honda Accord (low beam). Everyone says the 9006 is supposed to fit the socket. The socket is fine; the connector for the new bulb is covered by a plastic sheath, which the old bulb doesn't have. Should I go to a dealer for this part?
Art Brymer - 답글
Did you end up with a solution I'm having a similar issue
Samantha Rivera -
Bulb was out on left side 2001 accord. Decided to replace both bulbs but the receptacle on the right was different. It was set up to receive 2 small tabs instead of the 1 tab on the left side which received the 9006 bulb perfectly. I have never seen this before. Has anyone else had this happen?
Dennis - 답글
Worked for me "Champion 9006" on drivers side on a 1999 Honda Accord EX. Thank you!
jadelise - 답글
Hi i have an honda accord v6 2002 ex model and I would like to replace my halogen bulbs with GOD xenon bulbs but I am not aware of the model number and the ballast required for the bulbs.
vemula - 답글
Well The passenger side headlight has the Coolant tank and battery and other things in the way that make it nearly impossible to reach. Then, the light socket doesn’t twist out very easily..in fact I can’t even budge it…needs some kind of release fluid or something. It won’t turn at all. Any suggestions would help.
G Bonner - 답글
passenger side hood release? really,,,lol
saranojean - 답글
Dear all ,
I'm having Honda Accord 2001 automatic, driving seat switch seams not working , seat is completely in front of the starting it's very difficult to seat and drive kindly give me some tricks to solve this issue,
Thanks
zabihussaini@gmail.com
zabihussaini - 답글
This method doesn’t work for the V6 model. The airfilter tube obstructs driver's side bulb for the low beam and it seems undetachable. Can you please make a guide for the V6?
Johnson - 답글
I just bought a 2002 Honda Accord Sedan and cannot find where the hood support rod goes when your ready to close the hood. A picture would be great!
Margaret Smith - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 22
30일 전: 115
전체 시간: 161,289
