주요 콘텐츠로 건너뛰기
기기를 수리하세요
수리할 권리
상점
소개
PRE-REQ
부품
지정된 부품이 없습니다.
  1. Open the trunk using your key in the trunk key slot or by using the lever under the driver's console. Open the trunk using your key in the trunk key slot or by using the lever under the driver's console.
    • Open the trunk using your key in the trunk key slot or by using the lever under the driver's console.
  2. Remove the small plastic screw along the vertical edge of the trunk entrance using a flathead screwdriver. Carefully peel back the trunk liner from around the edge of trunk opening by the light. Locate the two panel tail light connectors located between the liner and the panel tail light assembly.
    • Remove the small plastic screw along the vertical edge of the trunk entrance using a flathead screwdriver.
    • Carefully peel back the trunk liner from around the edge of trunk opening by the light.
    • Locate the two panel tail light connectors located between the liner and the panel tail light assembly.
  3. SKIP THE UPGRADE
    Save by fixing with an all-in-one kit.
    Shop iPhone Fix Kits
    SKIP THE UPGRADE
  4. Grab a light bulb socket and turn it counterclockwise until it can be removed from its hole. Repeat this process for the other light bulb socket. Repeat this process for the other light bulb socket.
    • Grab a light bulb socket and turn it counterclockwise until it can be removed from its hole.
    • Repeat this process for the other light bulb socket.
  5. Locate the light bulb sockets in the trunk lid, located on the back side of the trunk tail lights. Turn the light bulb sockets counterclockwise and remove them from their holes. Turn the light bulb sockets counterclockwise and remove them from their holes.
    • Locate the light bulb sockets in the trunk lid, located on the back side of the trunk tail lights.
    • Turn the light bulb sockets counterclockwise and remove them from their holes.
결론
Miroslav Djuric
151,877 평판
안내서 143개 작성하였습니다
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 707
