소개
Use this guide to replace fogged or damaged tail lights in your '98-'02 Honda Accord.
부품
지정된 부품이 없습니다.
Open the trunk using your key in the trunk key slot or by using the lever under the driver's console.
Remove the small plastic screw along the vertical edge of the trunk entrance using a flathead screwdriver.
Carefully peel back the trunk liner from around the edge of trunk opening by the light.
Locate the two panel tail light connectors located between the liner and the panel tail light assembly.
Locate the light bulb sockets in the trunk lid, located on the back side of the trunk tail lights.
Turn the light bulb sockets counterclockwise and remove them from their holes.
Remove the connector at the bottom of the panel tail light assembly.
Locate the three 8 mm nuts holding the panel tail light assembly to the car and use an 8 mm socket wrench or box end wrench to remove the them.
다른 3명이 해당 안내서를 완성하였습니다.
댓글 4개
My tail lights, brake lights stay on even after I have turn the key off and pulled it out of the keyhole. Is there a part that might be broken that could repair this. Any comments I would appreciate them. Thanks oh I did find little pieces on the floor and wondered what that part might be maybe under the drivers side where the spring is
I have to take the cable off the battery or it goes dead. And the little part on the floor was kind of like a plastic washer with a little pointed top on it.
Thanks Nathan. The part was broken into pieces. There is a little spring underneath the steering and, back in a little bit that I wondered if it broke off from that, which would make the break stay on.
