주요 콘텐츠로 건너뛰기
1998-2002 Honda Accord Tail Lights Replacement
필요한 것
  1. 1998-2002 Honda Accord Tail Lights Replacement, Tail Light Bulb Assemblies: 1 단계, 이미지 1/2 1998-2002 Honda Accord Tail Lights Replacement, Tail Light Bulb Assemblies: 1 단계, 이미지 2/2
    • Open the trunk using your key in the trunk key slot or by using the lever under the driver's console.
  2. 1998-2002 Honda Accord Tail Lights Replacement, Panel Tail Lights: 2 단계, 이미지 1/3 1998-2002 Honda Accord Tail Lights Replacement, Panel Tail Lights: 2 단계, 이미지 2/3 1998-2002 Honda Accord Tail Lights Replacement, Panel Tail Lights: 2 단계, 이미지 3/3
    • Remove the small plastic screw along the vertical edge of the trunk entrance using a flathead screwdriver.
    • Carefully peel back the trunk liner from around the edge of trunk opening by the light.
    • Locate the two panel tail light connectors located between the liner and the panel tail light assembly.
  3. 1998-2002 Honda Accord Tail Lights Replacement: 3 단계, 이미지 1/3 1998-2002 Honda Accord Tail Lights Replacement: 3 단계, 이미지 2/3 1998-2002 Honda Accord Tail Lights Replacement: 3 단계, 이미지 3/3
    • Grab a light bulb socket and turn it counterclockwise until it can be removed from its hole.
    • Repeat this process for the other light bulb socket.
  4. 1998-2002 Honda Accord Tail Lights Replacement, Trunk Lid Tail Lights: 4 단계, 이미지 1/3 1998-2002 Honda Accord Tail Lights Replacement, Trunk Lid Tail Lights: 4 단계, 이미지 2/3 1998-2002 Honda Accord Tail Lights Replacement, Trunk Lid Tail Lights: 4 단계, 이미지 3/3
    • Locate the light bulb sockets in the trunk lid, located on the back side of the trunk tail lights.
    • Turn the light bulb sockets counterclockwise and remove them from their holes.
  5. 1998-2002 Honda Accord Tail Lights Replacement, Tail Lights: 5 단계, 이미지 1/2 1998-2002 Honda Accord Tail Lights Replacement, Tail Lights: 5 단계, 이미지 2/2
    • Remove the connector at the bottom of the panel tail light assembly.
    • Locate the three 8 mm nuts holding the panel tail light assembly to the car and use an 8 mm socket wrench or box end wrench to remove the them.
  6. 1998-2002 Honda Accord Tail Lights Replacement: 6 단계, 이미지 1/1
    • Remove the panel tail light assembly by pulling it straight away from the car.
    • If you are having troubles removing the light, try wiggling it back and forth as you pull it out.
  7. 1998-2002 Honda Accord Tail Lights Replacement: 7 단계, 이미지 1/3 1998-2002 Honda Accord Tail Lights Replacement: 7 단계, 이미지 2/3 1998-2002 Honda Accord Tail Lights Replacement: 7 단계, 이미지 3/3
    • Remove the three 8 mm hex nuts securing the trunk tail light using a socket wrench or box end wrench.
    • The black nut at the edge of the trunk lid has an extended round end that prevents a standard 8 mm socket from seating fully. You can use a regular socket if you can keep the bit level while rotating, but a deep socket is recommended to prevent stripping.
  8. 1998-2002 Honda Accord Tail Lights Replacement: 8 단계, 이미지 1/1
    • Lift the trunk tail light up from the outer edge, being careful not to break the plastic locator on the inside edge.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Miroslav Djuric
158,572 평판
안내서 144개 작성하였습니다
댓글 4개
I Installed led brakes and thay don't flash when I push on the brake that bottom wire is unhooked was wondering if that ran to the brake switch was wondering how to hard wire it will it would work
Nathan - 답글
My tail lights, brake lights stay on even after I have turn the key off and pulled it out of the keyhole. Is there a part that might be broken that could repair this. Any comments I would appreciate them. Thanks oh I did find little pieces on the floor and wondered what that part might be maybe under the drivers side where the spring is
LaDawn Berkey - 답글
I have to take the cable off the battery or it goes dead. And the little part on the floor was kind of like a plastic washer with a little pointed top on it.
LaDawn Berkey - 답글
Thanks Nathan. The part was broken into pieces. There is a little spring underneath the steering and, back in a little bit that I wondered if it broke off from that, which would make the break stay on.
LaDawn Berkey - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 9
30일 전: 47
전체 시간: 23,700
