소개
The timing belt and water pump should be replaced together every 60,000-75,000 miles.
Follow this video tutorial by YouTuber NutzAboutBolts to complete the replacement yourself.
필요한 것
동영상 지침
거의 끝나갑니다!
결론
다른 5명이 해당 안내서를 완성하였습니다.
댓글 7개
Ok i did my timing belt and wather pump its a lot of work but you need to remember to mark your belt and line up wheels i got the timing spot on thanks to this pag
Isaac - 답글
Is the 99 Accord a single cam?
Mr. Mackmillion - 답글
My 1998 accord is leaking water from the right side what is it
Zac Johnson - 답글
Hi Zac, it’s not possible to accurately diagnose a leak over the internet. It would be best to have someone, or a mechanic, to physically look at it to locate the leak.
Blake Klein -
I added coolant to the radiator and all of it leaked out . On top of that the engine overheats in a few minutes of driving . What would be an appropriate diagnosis
Amadu - 답글
