주요 콘텐츠로 건너뛰기
1998 Honda Accord Center Dash Disassembly
필요한 것
  1. 1998 Honda Accord Center Dash Disassembly, Center Dash: 1 단계, 이미지 1개 중 1개
    • Before going any further: disconnect the battery. I keep a 10 mm wrench in my center console specifically for this purpose.
    • Use a 10 mm wrench to disconnect the negative battery terminal, followed by the positive terminal.
  2. 1998 Honda Accord Center Dash Disassembly: 2 단계, 이미지 1개 중 1개
    • Note that the dash has been taken apart before, namely to install all those fancy gizmos you see in this picture.
    • The disassembly procedure is exactly the same for stock factory systems, but may differ when taking out the radio itself.
  3. 1998 Honda Accord Center Dash Disassembly: 3 단계, 이미지 1개 중 1개
    • Use a #2 Philips screwdriver to remove the two screws holding the center of the dashboard in place.
  4. 1998 Honda Accord Center Dash Disassembly: 4 단계, 이미지 2개 중 1개 1998 Honda Accord Center Dash Disassembly: 4 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    Spudger
    $3.99
    • Use a spudger for the following step or, if you don't have one handy, cover a flathead screwdriver with a rag.
    • Gently insert a spudger or flathead screwdriver directly underneath the clock, just enough so you can pry out the clock. Perhaps a half inch or so will do it.
  5. 1998 Honda Accord Center Dash Disassembly: 5 단계, 이미지 2개 중 1개 1998 Honda Accord Center Dash Disassembly: 5 단계, 이미지 2개 중 2개
    • Slide the clock out to expose a sole Phillips screw.
    • Alternatively, you can first disconnect the clock (see next step) and then proceed to remove the screw. It might be slightly easier to do that instead of the method you see here, but either way will work fine.
    • Remove the screw using your Phillips #2 screwdriver.
  6. 1998 Honda Accord Center Dash Disassembly: 6 단계, 이미지 2개 중 1개 1998 Honda Accord Center Dash Disassembly: 6 단계, 이미지 2개 중 2개
    • Unplug the smaller connector first. There's a tab on top of the connector that you have to push downwards, then pull the connector. Make sure to grasp the connector itself, and not the wires.
    • Do the same with the larger connector. Again, there's a tab on top that needs to be pushed downward.
  7. 1998 Honda Accord Center Dash Disassembly: 7 단계, 이미지 1개 중 1개
    • Now, gently pull the bottom of the center console towards you. Don't yank it out, there's two more connectors holding it in place.
  8. 1998 Honda Accord Center Dash Disassembly: 8 단계, 이미지 2개 중 1개 1998 Honda Accord Center Dash Disassembly: 8 단계, 이미지 2개 중 2개
    • First take off the red connector. Just like before, there's a tab on top of the connector that you have to push downwards first.
    • Follow suit with the green connector.
    • Center dash can now be fully removed.
결론
다른 8명이 해당 안내서를 완성하였습니다.
댓글 4개
Excellent Instructions. Toughest part is prying off the panel once you remove the screws and clock. The power connectors to the controls, (Hazards, Clock, Climate Control) can be a little tough too, wiggling helped.
Jason - 답글
My car radio is deactivated
Amelia davila - 답글
I need the inside lighting fixture on the front top of the dash
Robert Jones - 답글
How do you get the radio to turn on
Merlin Duston - 답글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 14
지난 30일: 32
전체 시간: 33,471
