이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
소개
This guide is applicable for any Accord made between 1998 and 2002.
필요한 것
Use a 10 mm wrench to disconnect the negative battery terminal, followed by the positive terminal.
Unplug the smaller connector first. There's a tab on top of the connector that you have to push downwards, then pull the connector. Make sure to grasp the connector itself, and not the wires.
Do the same with the larger connector. Again, there's a tab on top that needs to be pushed downward.
다른 8명이 해당 안내서를 완성하였습니다.
댓글 4개
My car radio is deactivated
I need the inside lighting fixture on the front top of the dash
How do you get the radio to turn on
