소개
Cars are a primary source of transportation for many people; when driven for a long time cars can experience wear, and accidents. In this guide, I will show people how to replace their worn out head/tail lights of their 1998 Toyota Camry . It is a priority to have these fixed as soon as possible because it is illegal in all states to have a broken head/ tail lights while driving. The main safety hazard that this fix poses is getting shocked, and that can be prevented by following the first step of the guide and turning the car off. One of the crucial requirement of this fast fix is to simply put on plastic gloves while switching out the head lights.
필요한 것
Make sure your car is turned off and check to make sure the head lights are not on.
This should take about 15-20 minutes to completely change all the head and tail lights in the car if you are unfamiliar with this process. Once someone is familiar with this it should not take them more than 10 minutes to complete the entire process.
다른 2명이 해당 안내서를 완성하였습니다.
