주요 콘텐츠로 건너뛰기
1999-2011 Ford Ranger Tail Light Bulb Replacement
필요한 것
  1. 1999-2011 Ford Ranger Tail Light Bulb Replacement, Tail Light Bulb: 1 단계, 이미지 1/3 1999-2011 Ford Ranger Tail Light Bulb Replacement, Tail Light Bulb: 1 단계, 이미지 2/3 1999-2011 Ford Ranger Tail Light Bulb Replacement, Tail Light Bulb: 1 단계, 이미지 3/3
    • Pull the tailgate latch and lower the tailgate down so that it is open.
  2. 1999-2011 Ford Ranger Tail Light Bulb Replacement: 2 단계, 이미지 1/3 1999-2011 Ford Ranger Tail Light Bulb Replacement: 2 단계, 이미지 2/3 1999-2011 Ford Ranger Tail Light Bulb Replacement: 2 단계, 이미지 3/3
    • Remove the two 19mm Phillips #1 screws on the taillight housing that face the inside of the bed.
    • Remove the two 38mm Phillips #1 screws on the taillight housing that face the outside of the truck.
  3. 1999-2011 Ford Ranger Tail Light Bulb Replacement: 3 단계, 이미지 1/3 1999-2011 Ford Ranger Tail Light Bulb Replacement: 3 단계, 이미지 2/3 1999-2011 Ford Ranger Tail Light Bulb Replacement: 3 단계, 이미지 3/3
    • Pull the taillight housing down from the truck so that the wires and plugs are exposed.
  4. 1999-2011 Ford Ranger Tail Light Bulb Replacement: 4 단계, 이미지 1/1
    • Remove any dirt or dust around the taillight plug so that nothing falls into the lens.
  5. 1999-2011 Ford Ranger Tail Light Bulb Replacement: 5 단계, 이미지 1/3 1999-2011 Ford Ranger Tail Light Bulb Replacement: 5 단계, 이미지 2/3 1999-2011 Ford Ranger Tail Light Bulb Replacement: 5 단계, 이미지 3/3
    • Loosen and remove the taillight plug so that the bulb is exposed.
  6. 1999-2011 Ford Ranger Tail Light Bulb Replacement: 6 단계, 이미지 1/3 1999-2011 Ford Ranger Tail Light Bulb Replacement: 6 단계, 이미지 2/3 1999-2011 Ford Ranger Tail Light Bulb Replacement: 6 단계, 이미지 3/3
    • Remove the old or damaged bulb.
    • Insert the new bulb into the exposed plug and then insert the plug back into the taillight housing and tighten.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Logan Walters
회원 가입일: 08/27/20
287 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 18
30일 전: 108
전체 시간: 6,984
