주요 콘텐츠로 건너뛰기
1999-2007 Ford Super Duty Seat Replacement
필요한 것
  1. 1999-2007 Ford Super Duty Seat Replacement, Seat: 1 단계, 이미지 1/1
    • Before shot of bench seat in a 2005 Ford F-350 Super Duty. Removal of the seat requires an 18mm socket. Preferably a deep wall socket and a T60 Torx Bit w/ratchet or impact wrench.
  2. 1999-2007 Ford Super Duty Seat Replacement: 2 단계, 이미지 1/2 1999-2007 Ford Super Duty Seat Replacement: 2 단계, 이미지 2/2
    • Adjust the seat as far back as you can. Using an 18mm deep wall socket, remove the bolts on the front that attachs the seat to the floor. On my bench seat there were only two bolts. If you have a 60/40 seat or bucket seats there will be more.
  3. 1999-2007 Ford Super Duty Seat Replacement: 3 단계, 이미지 1/3 1999-2007 Ford Super Duty Seat Replacement: 3 단계, 이미지 2/3 1999-2007 Ford Super Duty Seat Replacement: 3 단계, 이미지 3/3
    • Adjust seat to it's most forward position. Look for a stud with a plastic protection cap. Remove the cap with a screwdriver. Using an 18mm wrench or socket (if space allows) remove the bolt from the stud. On my bench seat there were only two studs/bolts. Other style seats will have more. Lift seat off studs and position seat forward of studs.
  4. 1999-2007 Ford Super Duty Seat Replacement: 4 단계, 이미지 1/3 1999-2007 Ford Super Duty Seat Replacement: 4 단계, 이미지 2/3 1999-2007 Ford Super Duty Seat Replacement: 4 단계, 이미지 3/3
    • Using the T60 Torx bit, remove the bolts attaching the seat belt receivers to the floor and remove the seat belt receivers.
  5. 1999-2007 Ford Super Duty Seat Replacement: 5 단계, 이미지 1/1
    • Unplug the seat belt receiver from the vehicle seat belt buzzer plug. it will be just under the back side of the seat.
    • You may now remove the old seat from the truck. if you have a bench seat like in this guide, you will need someone to help.
  6. 1999-2007 Ford Super Duty Seat Replacement: 7 단계, 이미지 1/3 1999-2007 Ford Super Duty Seat Replacement: 7 단계, 이미지 2/3 1999-2007 Ford Super Duty Seat Replacement: 7 단계, 이미지 3/3
    • Next, if your truck was only using the outter body holes you will need to locate the two close to the transmission tunnel. You can press your finger in the center and locate the opening. Take a razor knife and gently cut an X over the hole. Gently remove each of the triangle shaped tabs exposing the additional hole. Repeat on opposite side.
  7. 1999-2007 Ford Super Duty Seat Replacement: 8 단계, 이미지 1/2 1999-2007 Ford Super Duty Seat Replacement: 8 단계, 이미지 2/2
    • Next place your jump seat in the middle on top of the transmission tunnel. The rear holes will line up with two of the existing holes where the seat belts were attached. Place two bolts in the holes but don't tighten completely. Lift the bottom seat up exposing the two bolt holes in the bottom of the jump seat.
  8. 1999-2007 Ford Super Duty Seat Replacement: 9 단계, 이미지 1/1
    • Now mark and drill two holes in the transmission tunnel. Carefully check what is below the tunnel to make sure you don't damage wiring or other system that may be run along the path. This is best done with one person drilling and one person watching underneath. These are the only holes you must drill for 2011 to 2014 seats to fit.
  9. 1999-2007 Ford Super Duty Seat Replacement: 10 단계, 이미지 1/1
    • Notice the jump seat is a little lower than the buckets. Place your buckets in temporarily and use washers or other spacers between the floor and jump seat frame to adjust the jump seat to the same level as the buckets.
  10. 1999-2007 Ford Super Duty Seat Replacement: 11 단계, 이미지 1/3 1999-2007 Ford Super Duty Seat Replacement: 11 단계, 이미지 2/3 1999-2007 Ford Super Duty Seat Replacement: 11 단계, 이미지 3/3
    • Place your bucket seats in the truck. You should be able to line up all 4 holes in the seat frame with a hole in the truck body. You may use the same bolts you removed from the old seat to bolt the new seats down. Replace the plastic bolt covers on the new bucket seats.
  11. 1999-2007 Ford Super Duty Seat Replacement: 12 단계, 이미지 1/2 1999-2007 Ford Super Duty Seat Replacement: 12 단계, 이미지 2/2
    • In my case the seat belt buzzer on the new seat didn't match the vehicle plug. Simply remove the seat belt receiver from the side of the seat with a T60 Torq bit and re-attach your old seat belt receiver to the floor bolt. Using the old seat belt receiver gives you the proper connector and allows the buzzer to work properly.
  12. 1999-2007 Ford Super Duty Seat Replacement: 13 단계, 이미지 1/3 1999-2007 Ford Super Duty Seat Replacement: 13 단계, 이미지 2/3 1999-2007 Ford Super Duty Seat Replacement: 13 단계, 이미지 3/3
    • Be sure to tighten all bolts properly. Your safety depends on it. You now have modern much more comfortable seats in your truck. Enjoy. Before and After pics below.
결론
Replacing uncomfortable or worn out seat really improves your truck!
다른 21명이 해당 안내서를 완성하였습니다.
JNoles
회원 가입일: 03/20/13
623 평판
안내서 1개 작성함
Auburn Opelika Networks Auburn Opelika Networks 회원
Business
1 회원
안내서 3개 작성하였습니다
댓글 41개
Thanks for the amazing writeup! We are linking to here from our website on an upcoming blog. Once again, thanks for your business. Glad we could assist in your project.
-Keith B
OEM Seats
1-844-OEM-SEAT
oemcarandtruckseats - 답글
Thanks Keith. Your staff was very helpful and the seats look awesome! I would recommend your company to anyone! Keep up the good work.
JNoles - 답글
I see that your truck is the extended cab, will this work a single cab? I have the same year truck as a work truck but the bench seat is really uncomfortable on long trips. I would love that jump seat specially since it also works as a center console.
Lou Ramhart - 답글
From my understanding the front seat is the same regardless if it is a single cab, extended cab, or 4 door. If you will contact the good folks at http://www.oemcarandtruckseats.com/ I believe they can definitely answer your question. I can tell you this, if you change your bench seat out for the buckets with the jump seat it will be a 150% improvement in comfort.
JNoles -
I know this was posted two years ago early 2015. Do you know if a 2016 seat will fit?
Steve - 답글
댓글 쓰기
조회 통계:
24 시간 전: 20
7일 전: 95
30일 전: 518
전체 시간: 178,093
