주요 콘텐츠로 건너뛰기
1999-2006 BMW 3 Series Ignition Coils Replacement
필요한 것
  1. 1999-2006 BMW 3 Series Ignition Coils Replacement, Ignition Coils: 1 단계, 이미지 1/3 1999-2006 BMW 3 Series Ignition Coils Replacement, Ignition Coils: 1 단계, 이미지 2/3 1999-2006 BMW 3 Series Ignition Coils Replacement, Ignition Coils: 1 단계, 이미지 3/3
    • Release the hood latch by pulling the lever found in the driver foot well.
    • Open the hood.
  2. 1999-2006 BMW 3 Series Ignition Coils Replacement: 2 단계, 이미지 1/3 1999-2006 BMW 3 Series Ignition Coils Replacement: 2 단계, 이미지 2/3 1999-2006 BMW 3 Series Ignition Coils Replacement: 2 단계, 이미지 3/3
    • Remove the oil cap and note the four bolt placements.
  3. 1999-2006 BMW 3 Series Ignition Coils Replacement: 3 단계, 이미지 1/3 1999-2006 BMW 3 Series Ignition Coils Replacement: 3 단계, 이미지 2/3 1999-2006 BMW 3 Series Ignition Coils Replacement: 3 단계, 이미지 3/3
    • Using a 10 mm socket wrench, remove the four bolts holding down the engine covers.
  4. 1999-2006 BMW 3 Series Ignition Coils Replacement: 4 단계, 이미지 1/3 1999-2006 BMW 3 Series Ignition Coils Replacement: 4 단계, 이미지 2/3 1999-2006 BMW 3 Series Ignition Coils Replacement: 4 단계, 이미지 3/3
    • Note the placement of each ignition coil then remove the plastic latch and disconnect each cable.
  5. 1999-2006 BMW 3 Series Ignition Coils Replacement: 5 단계, 이미지 1/1
    • With a firm grip, remove each ignition coil and replace with the new coils respectively.
    • Repeat steps 4 to 1 for reassembly.
결론
다른 4명이 해당 안내서를 완성하였습니다.
Osama Almasri
회원 가입일: 10/14/20
217 평판
안내서 1개 작성함
University of Memphis, Team S2-G5, Willis Fall 2020 University of Memphis, Team S2-G5, Willis Fall 2020 회원
UM-WILLIS-F20S2G5
1 회원
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 7
30일 전: 59
전체 시간: 2,437
