주요 콘텐츠로 건너뛰기
1999-2004 Jeep Grand Cherokee Air Filter Replacement
필요한 것
  1. 1999-2004 Jeep Grand Cherokee Air Filter Replacement, Engine Compartment Air Filter: 1 단계, 이미지 1/1
    • Before you start, make sure the car is off and the parking break is on.
  2. 1999-2004 Jeep Grand Cherokee Air Filter Replacement: 2 단계, 이미지 1/2 1999-2004 Jeep Grand Cherokee Air Filter Replacement: 2 단계, 이미지 2/2
    • Pull out the hood release handle, which will pop up the hood of the car.
    • The release is located by the driver's seat to the left of the peddles.
  3. 1999-2004 Jeep Grand Cherokee Air Filter Replacement: 3 단계, 이미지 1/2 1999-2004 Jeep Grand Cherokee Air Filter Replacement: 3 단계, 이미지 2/2
    • Unlatch the hood of the car.
    • Stick your fingers in the gap between the hood and the grill, and feel for a little latch.
    • Press on the latch while also pushing the hood of the car up.
    • Once the hood is unlatched, push it all the way up. It's held there by struts so don't worry about finding the hood prop.
  4. 1999-2004 Jeep Grand Cherokee Air Filter Replacement: 4 단계, 이미지 1/3 1999-2004 Jeep Grand Cherokee Air Filter Replacement: 4 단계, 이미지 2/3 1999-2004 Jeep Grand Cherokee Air Filter Replacement: 4 단계, 이미지 3/3
    • The air filter housing is on the right front corner of the engine compartment.
    • Unlatch all four of the clips , which are located at the corners of the air filter housing and hold the housing together.
  5. 1999-2004 Jeep Grand Cherokee Air Filter Replacement: 5 단계, 이미지 1/2 1999-2004 Jeep Grand Cherokee Air Filter Replacement: 5 단계, 이미지 2/2
    • Gently lift the top half of the housing, and hold it off to the side with one hand.
    • Don't pull the housing too far to the side because it is still attached to the rest of the engine.
    • You can use a flathead screw driver to help pry up the top of the casing.
  6. 1999-2004 Jeep Grand Cherokee Air Filter Replacement: 6 단계, 이미지 1/2 1999-2004 Jeep Grand Cherokee Air Filter Replacement: 6 단계, 이미지 2/2
    • Remove the old air filter and clean any debris out of the bottom half of the housing.
  7. 1999-2004 Jeep Grand Cherokee Air Filter Replacement: 7 단계, 이미지 1/2 1999-2004 Jeep Grand Cherokee Air Filter Replacement: 7 단계, 이미지 2/2
    • Place the new filter in the bottom half of the housing.
    • Make sure the air filter is positioned correctly with the mesh side facing up.
  8. 1999-2004 Jeep Grand Cherokee Air Filter Replacement: 8 단계, 이미지 1/3 1999-2004 Jeep Grand Cherokee Air Filter Replacement: 8 단계, 이미지 2/3 1999-2004 Jeep Grand Cherokee Air Filter Replacement: 8 단계, 이미지 3/3
    • Place the top half of the housing back on the bottom half. Make sure the top fits tight back in place.
    • Reattach all four clips on the outside of the casing.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Kaylea Kleinschmit
회원 가입일: 10/08/20
211 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 26
30일 전: 78
전체 시간: 2,612
