주요 콘텐츠로 건너뛰기
1999-2004 Jeep Grand Cherokee Headlamp Unit Replacement
필요한 것
  1. 1999-2004 Jeep Grand Cherokee Headlamp Unit Replacement, Headlamp Unit: 1 단계, 이미지 1/3 1999-2004 Jeep Grand Cherokee Headlamp Unit Replacement, Headlamp Unit: 1 단계, 이미지 2/3 1999-2004 Jeep Grand Cherokee Headlamp Unit Replacement, Headlamp Unit: 1 단계, 이미지 3/3
    • Here is the Jeep GC. Removal of the headlamp is identical for both sides.
    • By opening the hood and looking straight down on the headlamp assembly, the 6mm hex head jack screw can be seen.
    • Use a 6mm socket and nut driver to remove the jack screw. 1/4 socket will not fit 9/32 does, but it is a bit sloppy
  2. 1999-2004 Jeep Grand Cherokee Headlamp Unit Replacement: 2 단계, 이미지 1/3 1999-2004 Jeep Grand Cherokee Headlamp Unit Replacement: 2 단계, 이미지 2/3 1999-2004 Jeep Grand Cherokee Headlamp Unit Replacement: 2 단계, 이미지 3/3
    • Remove the long jack screw.
    • Grasp upper inboard and lower outboard corners of headlamp and forcefully pull headlamp outward.
    • Remove all bulb sockets from headlamp module. Separate headlamp from vehicle.
결론
다른 6명이 해당 안내서를 완성하였습니다.
oldturkey03
회원 가입일: 09/29/10
782,216 평판
안내서 119개 작성하였습니다
Global Fixers Global Fixers 회원
Community
33 회원들
안내서 537개 작성하였습니다
댓글 4개
It’s a 7mm socket
Don Marcos - 답글
Not on mine. Just rechecked and it is a 6mm on my Jeep
oldturkey03 -
Thankful for simple instructions without any extra info or words ?
robinrogersk9 - 답글
I’m removing it to replace fan cooling module. I heard I can cut through to get to it without disassembling the grill bumper etc
robinrogersk9 - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 12
30일 전: 34
전체 시간: 7,561
