주요 콘텐츠로 건너뛰기
1999-2004 Nissan Xterra Headlight Bulbs Replacement
필요한 것
  1. 1999-2004 Nissan Xterra  Headlight Bulbs Replacement, Headlight Bulb: 1 단계, 이미지 1/2 1999-2004 Nissan Xterra  Headlight Bulbs Replacement, Headlight Bulb: 1 단계, 이미지 2/2
    • Reach under the driver's cabin panel and pull on the hood release.
    • It is about 10 inches from the left edge of the panel.
    • After pulling the release, you will hear a "pop" sound indicating that the hood is open.
  2. 1999-2004 Nissan Xterra  Headlight Bulbs Replacement: 2 단계, 이미지 1/1
    • Pull up the hood release latch.
    • It is located about 6 inches to the right, from the center of the hood.
  3. 1999-2004 Nissan Xterra  Headlight Bulbs Replacement: 3 단계, 이미지 1/2 1999-2004 Nissan Xterra  Headlight Bulbs Replacement: 3 단계, 이미지 2/2
    • Insert the hood support.
    • The support is located about 4 inches behind the hood latch opener.
  4. 1999-2004 Nissan Xterra  Headlight Bulbs Replacement: 4 단계, 이미지 1/3 1999-2004 Nissan Xterra  Headlight Bulbs Replacement: 4 단계, 이미지 2/3 1999-2004 Nissan Xterra  Headlight Bulbs Replacement: 4 단계, 이미지 3/3
    • Squeeze and disconnect the electrical component from the rear end of the bulb.
    • The squeezing should be done by placing one finger above and another below the component.
  5. 1999-2004 Nissan Xterra  Headlight Bulbs Replacement: 5 단계, 이미지 1/3 1999-2004 Nissan Xterra  Headlight Bulbs Replacement: 5 단계, 이미지 2/3 1999-2004 Nissan Xterra  Headlight Bulbs Replacement: 5 단계, 이미지 3/3
    • Turn the retaining ring counterclockwise until it is free from the headlight.
    • Remove this component and set it aside.
  6. 1999-2004 Nissan Xterra  Headlight Bulbs Replacement: 6 단계, 이미지 1/2 1999-2004 Nissan Xterra  Headlight Bulbs Replacement: 6 단계, 이미지 2/2
    • Carefully remove the headlight bulb.
    • The headlight bulb is immediately behind the retaining ring removed in Step 5.
    • High pressure halogen gas is sealed inside the halogen bulb. The bulb may break if the glass envelope is scratched or the bulb is dropped.
    • When handling the bulb, do not touch the glass envelope.
결론
To replace the headlight bulb, follow these instructions in reverse order with the new halogen bulb. When inserting the new bulb, ensure that the plastic outcropping is facing up to ensure that the bulb stays secure.
다른 3명이 해당 안내서를 완성하였습니다.
첨부 문서
Lance Cross
회원 가입일: 09/17/19
163 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 4
7일 전: 10
30일 전: 36
전체 시간: 5,548
