주요 콘텐츠로 건너뛰기
1999-2004 Volkswagen Golf Front Windshield Wipers Replacement
필요한 것
  1. 1999-2004 Volkswagen Golf Front Windshield Wipers Replacement, Front Windshield Wipers: 1 단계, 이미지 1/1
    • Use a flathead screwdriver to remove the cap from the windshield wiper.
  2. 1999-2004 Volkswagen Golf Front Windshield Wipers Replacement: 2 단계, 이미지 1/1
    • Use a socket wrench to release the passenger-side windshield wiper locking nut.
  3. 1999-2004 Volkswagen Golf Front Windshield Wipers Replacement: 3 단계, 이미지 1/2 1999-2004 Volkswagen Golf Front Windshield Wipers Replacement: 3 단계, 이미지 2/2
    • Gently lift up the passenger-side windshield wiper.
  4. 1999-2004 Volkswagen Golf Front Windshield Wipers Replacement: 4 단계, 이미지 1/1
    • Remove the driver-side windshield wiper in the same fashion.
    My windshield wipers were stuck on like they were welded. I removed them with channel lock pliers. I put the top jaw of the pliers and placed it under the wiper and the bottom claw of the pliers and put it on the mounting bolt. squeezed as hard as I could and Pop! It came loose.
    Nils Stansen - 답글
결론
다른 4명이 해당 안내서를 완성하였습니다.
Matthew Newsom
회원 가입일: 01/05/10
39,496 평판
안내서 67개 작성하였습니다
댓글 한 개
one has to be careful with the rain tray. if you use too much pressure whil trying to get the wipers off, you will damage (crack) it.
there is a special tool for getting them off; this is a bit pricey.
elchmartin - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 7
30일 전: 22
전체 시간: 13,764
