소개
Use this guide to remove the windshield wiper arms from your Golf.
필요한 것
Use a flathead screwdriver to remove the cap from the windshield wiper.
Remove the driver-side windshield wiper in the same fashion.
My windshield wipers were stuck on like they were welded. I removed them with channel lock pliers. I put the top jaw of the pliers and placed it under the wiper and the bottom claw of the pliers and put it on the mounting bolt. squeezed as hard as I could and Pop! It came loose.
다른 4명이 해당 안내서를 완성하였습니다.
댓글 한 개
one has to be careful with the rain tray. if you use too much pressure whil trying to get the wipers off, you will damage (crack) it.
there is a special tool for getting them off; this is a bit pricey.
elchmartin - 답글
