주요 콘텐츠로 건너뛰기
1999-2002 Suzuki SV650 Seat Replacement
필요한 것
  1. 1999-2002 Suzuki SV650 Seat Replacement, Seat: 1 단계, 이미지 1/2 1999-2002 Suzuki SV650 Seat Replacement, Seat: 1 단계, 이미지 2/2
    • If you have frame covers below your seat, remove them by removing the 4 mm allen bolts holding them on. Use a 4 mm allen wrench to turn the screws counter-clockwise until they come off.
    • Once the frame covers are off, remove the 4 mm allen seat bolts on both sides of the seat. Use the 4 mm allen wrench to turn the screws counter-clockwise until they come off.
    • The bolt in the picture is not stock.
    • Lift the front of the seat, then pull it off the frame.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Phillip Takahashi
회원 가입일: 08/22/11
86,704 평판
안내서 87개 작성하였습니다
댓글 한 개
seat bolts are actually 6mm Allen (side covers are 4mm Allen).
thineownself - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 18
30일 전: 53
전체 시간: 7,880
