주요 콘텐츠로 건너뛰기
1999 GMC Suburban Brake Light Replacement
필요한 것
  1. 1999 GMC Suburban Brake Light Replacement, Brake Light: 1 단계, 이미지 3개 중 1개 1999 GMC Suburban Brake Light Replacement, Brake Light: 1 단계, 이미지 3개 중 2개 1999 GMC Suburban Brake Light Replacement, Brake Light: 1 단계, 이미지 3개 중 3개
    • Before you begin, turn off your car, put it in park, and engage the emergency brake.
    • Select the side of the car you would like to work on first.
    • Open the trunk doors.
  2. 1999 GMC Suburban Brake Light Replacement: 2 단계, 이미지 3개 중 1개 1999 GMC Suburban Brake Light Replacement: 2 단계, 이미지 3개 중 2개 1999 GMC Suburban Brake Light Replacement: 2 단계, 이미지 3개 중 3개
    • These two holes have screws inside of them, so unscrew them to get the brake light out.
    • The screws that will be removed for this step are "Round washer head pozi-drive tapping screw tail lamp assembly M4.2-1.41 x 20mm".
  3. 1999 GMC Suburban Brake Light Replacement: 3 단계, 이미지 3개 중 1개 1999 GMC Suburban Brake Light Replacement: 3 단계, 이미지 3개 중 2개 1999 GMC Suburban Brake Light Replacement: 3 단계, 이미지 3개 중 3개
    • When removing the tail light there are little hooks with holes that are used to hold them in place as shown in the first photo.
    • The tail should already be loose from the previous step so pull it out slowly by turning it on its side and then pulling forward.
    • Use the 7 mm socket to unscrew the two bolts securing the brake light housing to the tail light assembly.
    • The screws in this step are "Rexka 30pcs M4.2-1.41 x 20mm".
  4. 1999 GMC Suburban Brake Light Replacement: 4 단계, 이미지 2개 중 1개 1999 GMC Suburban Brake Light Replacement: 4 단계, 이미지 2개 중 2개
    • After taking off the screws, take the brake lights out and find which light isn't working by stepping on the brake.
  5. 1999 GMC Suburban Brake Light Replacement: 5 단계, 이미지 1개 중 1개
    • With the actual light, unplug them by pulling them out but not with too much force.
    • Plug the new light bulb(s) in place of the ones that don't work.
    • Please be careful with how you remove the bulbs because they are made of glass.
  6. 1999 GMC Suburban Brake Light Replacement: 6 단계, 이미지 2개 중 1개 1999 GMC Suburban Brake Light Replacement: 6 단계, 이미지 2개 중 2개
    • Now put everything back together and put all the screws back on.
    • The steps are the same on both sides and is a fairly simple and fast process.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Marcos Shipley
회원 가입일: 10/25/23
154 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 4
지난 30일: 28
전체 시간: 544
