주요 콘텐츠로 건너뛰기
1Home sensor bin lid stopped working after cleaning
필요한 것
  1. 1Home sensor bin lid stopped working after cleaning, Lid disassembly: 1 단계, 이미지 2개 중 1개 1Home sensor bin lid stopped working after cleaning, Lid disassembly: 1 단계, 이미지 2개 중 2개
    • With a philips n.2 screw, removewthe 6 screws that hold the main two parts of the lid together.
  2. 1Home sensor bin lid stopped working after cleaning, Dry the water: 2 단계, 이미지 3개 중 1개 1Home sensor bin lid stopped working after cleaning, Dry the water: 2 단계, 이미지 3개 중 2개 1Home sensor bin lid stopped working after cleaning, Dry the water: 2 단계, 이미지 3개 중 3개
    • You'll probably see water accumulated in a few areas, and everything will be wet.
    • With a paper towel, go throughly drying everywhere you see water.
    • Careful when managing this step, there are wires tethering the two parts and these are soldered, can't be removed.
  3. 1Home sensor bin lid stopped working after cleaning, Dry the IR sensor board: 3 단계, 이미지 3개 중 1개 1Home sensor bin lid stopped working after cleaning, Dry the IR sensor board: 3 단계, 이미지 3개 중 2개 1Home sensor bin lid stopped working after cleaning, Dry the IR sensor board: 3 단계, 이미지 3개 중 3개
    • There are three small screws holding the sensor board. unscrew them to have access to the other side of the board and the plastic lid
    • Optionally, a bit of Isopropyl alcohol with a cotton bud can be rubbed over the boards, and this evaporates very quickly.
    • Make sure to squeeze a bit of paper towel in the sensors cavity, there's most likely water there!
  4. 1Home sensor bin lid stopped working after cleaning, Clean and re-grease the spring and gears: 4 단계, 이미지 1개 중 1개
    • Before reassembling, I cleaned this spring that opens the lid, since I couldn't tell if this was lubricating grease or just disgusting grease. I replaced it with a bit of lubricating grease, but I doubt this is needed.
    • i also added a little bit of grease to the gears at the other side (forgot to take a picture)
결론
작성자
1다른 기여자 명과 함께
palako
회원 가입일: 02/01/15
992 평판
안내서 7개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 10
지난 30일: 51
전체 시간: 1,218
