주요 콘텐츠로 건너뛰기
2 - Kettles - How does it work?
  1. 2 - Kettles - How does it work?, General operating principles: 1 단계, 이미지 3개 중 1개 2 - Kettles - How does it work?, General operating principles: 1 단계, 이미지 3개 중 2개 2 - Kettles - How does it work?, General operating principles: 1 단계, 이미지 3개 중 3개
    • The principles are simple. The base is connected to the mains via the power cord. When the reservoir is placed on the base, the 3a 3b device powers the resistor at the bottom of the reservoir. A 6 switch on the reservoir handle switches the power on and off.
  2. 2 - Kettles - How does it work?, Description of reservoir parts: 2 단계, 이미지 1개 중 1개
    • The reservoir consists of a plastic shell with a handle. Inside this handle is a 6 switch for switching on the kettle. The resistor 4 placed inside, is fixed by three screws to the connection device 3b A gasket 5 ensures watertightness.
    • The 6 switch is connected to the 3b device located at the bottom of the reservoir, by a plastic rod which, by translation, activates an electrical contact system.
  3. 2 - Kettles - How does it work?, Operation of the on/off device: 3 단계, 이미지 3개 중 1개 2 - Kettles - How does it work?, Operation of the on/off device: 3 단계, 이미지 3개 중 2개 2 - Kettles - How does it work?, Operation of the on/off device: 3 단계, 이미지 3개 중 3개
    • The 3 device is the centerpiece of this kettle. It performs a number of functions: - electrical connection between the base and the reservoir - manual switching on and off of the heating element - automatic switching off when the water temperature is reached.
    • It consists of 2 parts. One, placed on the base 3a, the other placed at the base of the tank, 3b. The latter performs all 3 functions. It is made up of a system of metal fins which are activated to make electrical contact.
    • The resistor has two 7 terminals mounted on a 12 metal support. Part 3 is made of metal fins. The 9 and 10 blades come into contact with the 7 resistor terminals. The 8 blade comes into contact with the 12 support.
    • The ON/OFF switch 11 is located on top of part 3.
    • When this button is switched on, the 9 blade is activated, allowing current to flow between the socket in the base and one of the 7 terminals on the resistor.
    • The 10 reed is normally closed (the water is cold), so the current can pass through and feed the resistor, which starts to heat. When the temperature is reached, the 8 reed deforms and opens the circuit by toggling the 11 switch. The resistor stops heating. The M/A button 6 returns to its position at the stop.
결론
Now that we know the functions of our appliance and are familiar with its subassemblies and operation, we can move on to the repair phase with the following tuto: "Kettles - Common breakdowns"
다른 2명이 해당 안내서를 완성하였습니다.
다음 번역가들에게 특별히 감사 드립니다:
fr en
100%
shingle님은 저희가 세상을 수리하는데 동참하신 분입니다! 기여하시겠습니까?
번역 시작하기 ›
작성자
1다른 기여자 명과 함께
Atelier Soudé
회원 가입일: 12/13/18
4,642 평판
안내서 18개를 작성함
Atelier Soudé Atelier Soudé 회원
Local Repair Groups
5 회원들
안내서 43개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 6
지난 30일: 29
전체 시간: 813
