소개
There are many signs to tell if your car battery has died or is close to dying. If you turn the car on and before it goes to idle the car shuts off, or if the lights on the car work, but the car itself will not do anything when you turn the key. The battery, along with the alternator, are the only sources of power for a 2000 Acura TL.
Before changing the battery in your Acura TL, try and get a jump start from somebody else, and if after the jumpstart, your car does not run much longer, then it is time to change the battery. It is important to differentiate between the alternator and the battery before making a larger purchase such as a new car battery.
Replacing a car battery for a 2000 Acura TL will be likely because the car itself is older at this point and will likely need one if the car battery has not been replaced. Replacing the battery yourself will save a lot of money and save a trip to the mechanic if not necessary.
Before beginning make sure the car is off and has had time to cool down before beginning to work on the battery.
필요한 것
Use the socket wrench with a 10mm socket to loosen the bolts on the guard that sits on top of the battery.
After making sure all parts are secured on the battery. the car is ready to go! Dispose of the battery at your nearest auto parts store or at your city dump.
