주요 콘텐츠로 건너뛰기
2000 Gmc Sierra Light Replacement
필요한 것
  1. 2000 Gmc Sierra Light Replacement, Headlights, Taillights, and an overhead light: 1 단계, 이미지 1/1
    • Open your tailgate fully, exposing both sides where the tailgate sits.
  2. 2000 Gmc Sierra Light Replacement: 2 단계, 이미지 1/1
    • Unscrew the two phillips head screws located above and below the tailgate support.
  3. 2000 Gmc Sierra Light Replacement: 3 단계, 이미지 1/1
    • Once the screws have been removed, simply pull off the taillight. The red plug is the taillight. Twist it a quarter turn counter clockwise, and pop it out.
  4. 2000 Gmc Sierra Light Replacement: 4 단계, 이미지 1/1
    • Remove the old bulb and replace it with your new one.
    • Side note: Make sure replacement bulb is save voltage/amperage rating.
    • Open the hood and take a look above your headlights.
    • Two metal pins holding each of the headlights in place will need to be removed (no tool necessary).
    • Turn the plastic headlight mount counter clockwise by one quarter of a turn.
    • Then lift the pins up to fully remove them.
    • Once the pins have been removed, GENTLY pull your headlight upwards, towards you. The bulbs should now be exposed. The bulb on the top is your headlight.
    • As you did with the taillight bulb, turn the piece that is holding the bulb in place a quarter turn counter clockwise, and the bulb will pop out. Now your new bulb will take it's place.
결론
다른 5명이 해당 안내서를 완성하였습니다.
keith beaudoin
회원 가입일: 10/11/13
275 평판
안내서 1개 작성함
UMass Dartmouth, Team 4-7, Vijaybhaskar Fall 2013 UMass Dartmouth, Team 4-7, Vijaybhaskar Fall 2013 회원
UMASSD-VIJAYBHASKAR-F13S4G7
2 회원들
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 13
전체 시간: 500
