주요 콘텐츠로 건너뛰기
2001-2006 Mini Cooper Cabin Air Filter Replacement
  1. 2001-2006 Mini Cooper Cabin Air Filter Replacement, Cabin Air Filter: 1 단계, 이미지 1/3 2001-2006 Mini Cooper Cabin Air Filter Replacement, Cabin Air Filter: 1 단계, 이미지 2/3 2001-2006 Mini Cooper Cabin Air Filter Replacement, Cabin Air Filter: 1 단계, 이미지 3/3
    • Locate the air filter housing unit below the glove box.
    • Open housing unit to reach air filter by locating the three clips, one on the rear of the box and the two on the front.
    • Open the rear clip first by applying an outward and downward force. Repeat process for the front clips.
  2. 2001-2006 Mini Cooper Cabin Air Filter Replacement: 2 단계, 이미지 1/2 2001-2006 Mini Cooper Cabin Air Filter Replacement: 2 단계, 이미지 2/2
    • Filter lays in a pair of guide rails for easy removal and replacement.
    • Pinch base of filter with thumb.
    • Once the filter is pinched it can easily be pulled out by the guide rails with moderate force.
  3. 2001-2006 Mini Cooper Cabin Air Filter Replacement: 3 단계, 이미지 1/1
    • Replace the old filter with the new filter.
    • Reassemble the air filter by following the guide in reverse. On the side of the filter, there should be writing telling which direction the air flow goes in for putting it back in right way up. The air should be flowing into the foot well so you want the arrows pointing down.
결승점
다른 5명이 해당 안내서를 완성하였습니다.
Eli
회원 가입일: 10/10/13
363 평판
안내서 1개 작성함
Cal Poly, Team 8-19, Regan Fall 2013 Cal Poly, Team 8-19, Regan Fall 2013 회원
CPSU-REGAN-F13S8G19
3 회원들
안내서 4개 작성하였습니다
댓글 한 개
thank you for your page…you made it easy to understand…and the pics were great also!
Debbie Ross - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 10
30일 전: 70
전체 시간: 8,029
