주요 콘텐츠로 건너뛰기
2001-2006 Mini Cooper Door Handle and Small Speaker Disassembly
필요한 것
  1. 2001-2006 Mini Cooper Door Handle and Small Speaker Disassembly, Door panel: 1 단계, 이미지 1/2 2001-2006 Mini Cooper Door Handle and Small Speaker Disassembly, Door panel: 1 단계, 이미지 2/2
    • The first step is to remove the door handle and speaker cover. This is easily done by prying it off the plastic tabs with a flathead screwdriver or possibly even your hands.
    • Next you need to remove the four size T30 torx screws that hold the panel in place. Three of these are in the obvious screw holes shown but the last is hidden behind the colored reflector, which you will need to pry off. It is easy to remove with a small flathead screwdriver. Of the four screws, two are 18mm and the other two are 52.5mm long.
  2. 2001-2006 Mini Cooper Door Handle and Small Speaker Disassembly: 2 단계, 이미지 1/2 2001-2006 Mini Cooper Door Handle and Small Speaker Disassembly: 2 단계, 이미지 2/2
    • With the screws removed, you will need to pry the panel off of the door using a prybar or flathead screwdriver. I wrapped my screwdriver in electrical tape to keep it from scratching the car.
    • The bottom and sides of the panel are held on with one type of clip while the top is held on by another. Because of this, you want to start prying it somewhere along the bottom edge of the panel, I chose the lower outside corner.
  3. 2001-2006 Mini Cooper Door Handle and Small Speaker Disassembly: 3 단계, 이미지 1/2 2001-2006 Mini Cooper Door Handle and Small Speaker Disassembly: 3 단계, 이미지 2/2
    • Once you have the bottom and sides of the panel popped off the tabs, you want to to a combination of lifting and pulling along the top edge to remove it from these other types of tabs.
    • Once the panel is free from these, you can slide it over the door lock knob and pull the whole thing away.
    • That's it. You now have access to the rest of the door. In order to put the panel back on, just follow these directions in reverse order.
  4. 2001-2006 Mini Cooper Door Handle and Small Speaker Disassembly, Door Handle and Small Speaker: 4 단계, 이미지 1/3 2001-2006 Mini Cooper Door Handle and Small Speaker Disassembly, Door Handle and Small Speaker: 4 단계, 이미지 2/3 2001-2006 Mini Cooper Door Handle and Small Speaker Disassembly, Door Handle and Small Speaker: 4 단계, 이미지 3/3
    • After removing the door panel, you will have access to the door handle assembly.
    • This assembly is attached to the door with three Phillips screws, which you will need to remove.
    • Once those screws are removed, the assembly is free from the door, allowing access to the door lock cable and the window actuator. Replacing the handle assembly requires screwing it back into the yellow screwholes shown.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Eliot Kahn
회원 가입일: 10/09/13
575 평판
안내서 2개 작성하였습니다
Cal Poly, Team 8-19, Regan Fall 2013 Cal Poly, Team 8-19, Regan Fall 2013 회원
CPSU-REGAN-F13S8G19
3 회원들
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 33
전체 시간: 4,450
