주요 콘텐츠로 건너뛰기
2001-2005 Honda Civic Battery Replacement
필요한 것
  1. 2001-2005 Honda Civic Battery Replacement, Battery: 1 단계, 이미지 1/1
    • Caution! Vehicle must be turned off before attempting this replacement. Touching the battery terminals while the car is running may cause risk of electrocution.
  2. 2001-2005 Honda Civic Battery Replacement: 2 단계, 이미지 1/1
    • Remove the connections from both the negative and the positive terminals of the battery
    • When removing the battery, the negative terminal must be removed first. When re-installing the battery, the positive must be connected first.
  3. 2001-2005 Honda Civic Battery Replacement: 3 단계, 이미지 1/1
    • Using a socket wrench, remove the battery bracket from the top of the battery.
    • Depending on the condition of the car, the bolts may be rusted, making the removal of them a challenge.
  4. 2001-2005 Honda Civic Battery Replacement: 4 단계, 이미지 1/1
    • Ensure that there are no connections remaining on the battery.
    • Lift up the battery and remove it from the battery tray.
결론
다른 10명이 해당 안내서를 완성하였습니다.
Tyler Smith
회원 가입일: 10/23/13
846 평판
안내서 3개 작성하였습니다
UMass Dartmouth, Team 4-5, Vijaybhaskar Fall 2013 UMass Dartmouth, Team 4-5, Vijaybhaskar Fall 2013 회원
UMASSD-VIJAYBHASKAR-F13S4G5
3 회원들
안내서 5개 작성하였습니다
댓글 한 개
Terrible! These sparse instructions leave out so many steps, both for safety and for completion of the task, that anyone performing this task for the first time will have no idea what to do.
Mark - 답글
댓글 쓰기
조회 통계:
24 시간 전: 6
7일 전: 41
30일 전: 198
전체 시간: 36,353
