주요 콘텐츠로 건너뛰기
2001-2005 Honda Civic Front Brake Pads and Rotor Replacement
필요한 것
동영상 지침
결론
다른 2명이 해당 안내서를 완성하였습니다.
eCuration
회원 가입일: 05/19/17
376,693 평판
안내서 234개 작성하였습니다
iFixit iFixit 회원
Staff
135 회원들
안내서 16,817개 작성하였습니다
댓글 2개
kudos for making the video. The main reason I like to “see” these jobs done is to know what to expect before I start a job. I haven’t seen an impact screw driver in forty years though!
Stephan Eichinger - 답글
Change your video… 80K views for a non-pro... The slots in the surface are for Gas Evacuation; ie: from the resin in the pads. The slotted rotors fins are for cooling. If you are in there for rotors: Why Not pull the pads ( and de-glaze with some emery-paper on a true surface). Pull and lube the sliders and re-anti-seize the pad-backs and clips ? ps: Compress the pistons makes sure they slide. This is basic brake-care and you should get at least two pads sets to one rotor replacement. ps: Don’t learn from me- i ain’t no pro. pps: Me too with a rotor-parts mix-up even after watching the 'Pro's' at SouthmainAuto and Ericthecarguy.
paul rattenbury - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 9
30일 전: 58
전체 시간: 13,092
