소개
If you are experiencing a noise when breaking or pulsating pedal, it may be time to replace your brake pads and rotors.
Follow this video guide to replace the front brakes on your 2001-2005 Honda Civic.
필요한 것
동영상 지침
거의 끝나갑니다!
결론
다른 2명이 해당 안내서를 완성하였습니다.
댓글 2개
kudos for making the video. The main reason I like to “see” these jobs done is to know what to expect before I start a job. I haven’t seen an impact screw driver in forty years though!
Stephan Eichinger - 답글
Change your video… 80K views for a non-pro... The slots in the surface are for Gas Evacuation; ie: from the resin in the pads. The slotted rotors fins are for cooling. If you are in there for rotors: Why Not pull the pads ( and de-glaze with some emery-paper on a true surface). Pull and lube the sliders and re-anti-seize the pad-backs and clips ? ps: Compress the pistons makes sure they slide. This is basic brake-care and you should get at least two pads sets to one rotor replacement. ps: Don’t learn from me- i ain’t no pro. pps: Me too with a rotor-parts mix-up even after watching the 'Pro's' at SouthmainAuto and Ericthecarguy.
paul rattenbury - 답글
