소개
This is a step-by-step guide on how to replace a tail light bulb in a 2002-2009 Chevrolet Trailblazer. In this guide, I will be replacing the stoplight. With time, you will see that lights on your tail light need to be replaced. One special requirement I suggest is to wear gloves when handling the new bulb because you don’t want the oil from your skin to get on the bulb and already decrease its quality.
Before beginning, be sure to power off the ignition, place your car in park, and engage the parking brake.
필요한 것
Open up the trunk.
Remove the two screws next to the tail light using a Phillips #0 screwdriver.
다른 2명이 해당 안내서를 완성하였습니다.
