주요 콘텐츠로 건너뛰기
2002-2008 Dodge Ram 1500 Coolant replacement
필요한 것
  1. 2002-2008 Dodge Ram 1500 Coolant replacement, Engine Coolant: 1 단계, 이미지 1/3 2002-2008 Dodge Ram 1500 Coolant replacement, Engine Coolant: 1 단계, 이미지 2/3 2002-2008 Dodge Ram 1500 Coolant replacement, Engine Coolant: 1 단계, 이미지 3/3
    • Locate the coolant reservoir, near the front of the engine bay.
    • Do not remove the reservoir cap if the engine has overheated. Doing so may result in a steam explosion as pressure is released.
    • Locate the coolant reservoir cap and remove it by pressing down and turning it counterclockwise.
    • Never fill up the coolant while the engine is hot. This may cause the engine block to crack.
    • If the coolant level is low, fill up the reservoir using a 50/50 mixture of antifreeze and distilled water.
    • Many types of antifreeze coolant are pre-mixed, so read the instructions on the bottle before diluting with water.
  2. 2002-2008 Dodge Ram 1500 Coolant replacement: 2 단계, 이미지 1/3 2002-2008 Dodge Ram 1500 Coolant replacement: 2 단계, 이미지 2/3 2002-2008 Dodge Ram 1500 Coolant replacement: 2 단계, 이미지 3/3
    • If you need to completely drain the coolant, place a bucket underneath the coolant hose, near the front of the engine.
    • Locate and loosen the hose clamp on the coolant hose with the flat head screwdriver. The coolant hose is located near the bottom of the serpentine belt underneath the front of the engine bay.
    • Drain the coolant completely and reattach the coolant hose, tightening the hose clamp with the flat head screwdriver.
    • Dispose of your used coolant at an auto parts shop or a landfill that accepts hazardous materials. Do not pour it down a storm drain or sink.
    • Remember to refill the reservoir tank with coolant before driving your Dodge truck. Driving without coolant will cause overheating and engine damage.
    • Due to limited resources the coolant was not actually drained in this guide.
결론
To dispose of your used coolant, take it to an automotive parts store or to any landfill that accepts hazardous materials. Do not pour coolant down any drains or sinks. Serious ecological damage could occur.
다른 4명이 해당 안내서를 완성하였습니다.
Michael Saggese
회원 가입일: 10/05/12
1,021 평판
안내서 6개 작성하였습니다
Cal Poly, Team 3-24, Amido Fall 2012 Cal Poly, Team 3-24, Amido Fall 2012 회원
CPSU-AMIDO-F12S3G24
4 회원들
안내서 11개 작성하였습니다
댓글 한 개
Thanks a million very helpful advice !
kenneth.williamsbam - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 30
30일 전: 136
전체 시간: 55,172
