주요 콘텐츠로 건너뛰기
2002-2008 Dodge Ram 1500 Differential Oil Replacement
필요한 것
  1. 2002-2008 Dodge Ram 1500 Differential Oil Replacement, Differential Oil: 1 단계, 이미지 1/2 2002-2008 Dodge Ram 1500 Differential Oil Replacement, Differential Oil: 1 단계, 이미지 2/2
    • Locate the twelve 10mm long 14mm hex head bolts holding on the backplate of the differential.
    • Position an oil pan under the differential.
    • Loosen the bottom 4 bolts first with the 14mm socket wrench. Slowly loosen the rest of the bolts in a random order until oil flows out and enters the drain pan.
    • Due to limited resources the oil was not actually replaced in this guide.
  2. 2002-2008 Dodge Ram 1500 Differential Oil Replacement: 2 단계, 이미지 1/1
    • When tightening the bolts on the diff plate it is vital that you tighten them in a star pattern to avoid warping the plate. Do not exceed a torque of 40 ft-lbs per bolt.
    • Repeat the last step in reverse to re-tighten the bolts on the differential cover while following the star method of tightening bolts. Use a torque wrench to ensure proper torque specifications.
    • Now the differential is fully sealed and ready for new oil.
  3. 2002-2008 Dodge Ram 1500 Differential Oil Replacement: 3 단계, 이미지 1/2 2002-2008 Dodge Ram 1500 Differential Oil Replacement: 3 단계, 이미지 2/2
    • Locate the differential filler plug.
    • Use a #2 flathead screwdriver to lift the outer lip of the plug. Pinch the outer lip of the rubber filler plug between your fingers and pull off.
    • Use a vacuum pump to pump in new differential fluid until the oil level reaches the bottom of the plug hole.
    • Re-insert the rubber filler plug.
    • Due to limited resources the differential oil was not changed in this guide.
결론
다른 5명이 해당 안내서를 완성하였습니다.
Ken
회원 가입일: 10/05/12
548 평판
안내서 2개 작성하였습니다
Cal Poly, Team 3-24, Amido Fall 2012 Cal Poly, Team 3-24, Amido Fall 2012 회원
CPSU-AMIDO-F12S3G24
4 회원들
안내서 11개 작성하였습니다
댓글 2개
Don’t forget the clean the old gasket material off, wipe up any differential fluid residue, clean the mating surface with brake cleaner, and add a new gasket maker material.
This guide really left out some very important steps. And don’t reuse your diff fluid people.
N S A (Nick) - 답글
No mention of anti-slip additive which is not optional.
Ralph Parker - 답글
댓글 쓰기
조회 통계:
24 시간 전: 7
7일 전: 24
30일 전: 102
전체 시간: 37,047
