이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Locate the twelve 10mm long 14mm hex head bolts holding on the backplate of the differential.
Position an oil pan under the differential.
Loosen the bottom 4 bolts first with the 14mm socket wrench. Slowly loosen the rest of the bolts in a random order until oil flows out and enters the drain pan.
Repeat the last step in reverse to re-tighten the bolts on the differential cover while following the star method of tightening bolts. Use a torque wrench to ensure proper torque specifications.
Now the differential is fully sealed and ready for new oil.
Locate the differential filler plug.
Use a #2 flathead screwdriver to lift the outer lip of the plug. Pinch the outer lip of the rubber filler plug between your fingers and pull off.
Use a vacuum pump to pump in new differential fluid until the oil level reaches the bottom of the plug hole.
Re-insert the rubber filler plug.
다른 5명이 해당 안내서를 완성하였습니다.
댓글 2개
Don’t forget the clean the old gasket material off, wipe up any differential fluid residue, clean the mating surface with brake cleaner, and add a new gasket maker material.
This guide really left out some very important steps. And don’t reuse your diff fluid people.
No mention of anti-slip additive which is not optional.
