주요 콘텐츠로 건너뛰기
2002-2008 Dodge Ram 1500 Front Turn Signal Bulb Replacement
필요한 것
  1. 2002-2008 Dodge Ram 1500 Front Turn Signal Bulb Replacement, Headlight Assembly: 1 단계, 이미지 1/3 2002-2008 Dodge Ram 1500 Front Turn Signal Bulb Replacement, Headlight Assembly: 1 단계, 이미지 2/3 2002-2008 Dodge Ram 1500 Front Turn Signal Bulb Replacement, Headlight Assembly: 1 단계, 이미지 3/3
    • Open the hood by pulling the hood lever in the driver-side footwell.
    • Reach under the center of the grille and press the hood latch.
  2. 2002-2008 Dodge Ram 1500 Front Turn Signal Bulb Replacement: 2 단계, 이미지 1/1
    • In this guide we will be removing the left headlight. The steps are mirrored for the right headlight.
  3. 2002-2008 Dodge Ram 1500 Front Turn Signal Bulb Replacement: 3 단계, 이미지 1/3 2002-2008 Dodge Ram 1500 Front Turn Signal Bulb Replacement: 3 단계, 이미지 2/3 2002-2008 Dodge Ram 1500 Front Turn Signal Bulb Replacement: 3 단계, 이미지 3/3
    • Use the 10 mm socket wrench to unscrew the first of three 12 mm long 10 mm hex-head screws holding in the headlight assembly. The screw is located just to the left of the headlight assembly.
    • Unscrew the second screw located approximately 6 inches below the first.
    • Locate the third screw at the bottom left corner of the headlight assembly just behind the bumper and remove.
    • When re-installing the screws do not over tighten. Over tightening the screws will result in stripped threads.
  4. 2002-2008 Dodge Ram 1500 Front Turn Signal Bulb Replacement: 4 단계, 이미지 1/2 2002-2008 Dodge Ram 1500 Front Turn Signal Bulb Replacement: 4 단계, 이미지 2/2
    • Approach this step with the process of unbuttoning a shirt in mind.
    • Be careful if the rubber gasket is dry-rotted. Use vaseline to re-moisturize if necessary. Manipulating dry-rotted rubber will result in tearing.
    • Pinch the bottom of the rubber gasket at the left side of the assembly and remove it from the plastic "buttons" on the headlight assembly.
  5. 2002-2008 Dodge Ram 1500 Front Turn Signal Bulb Replacement: 5 단계, 이미지 1/2 2002-2008 Dodge Ram 1500 Front Turn Signal Bulb Replacement: 5 단계, 이미지 2/2
    • Locate the blue headlight wire. Use a flathead screwdriver to pry up one side of the clamping teeth and pull the connector off.
    • Locate the green turn signal wire clamp. Use a flathead screwdriver to push in the tab on the side and pull off the connector.
    • Now that all connections between the car and the headlight assembly are disconnected, it is safe to remove the headlight assembly from the truck.
  6. 2002-2008 Dodge Ram 1500 Front Turn Signal Bulb Replacement, Front Turn Signal Bulb: 6 단계, 이미지 1/3 2002-2008 Dodge Ram 1500 Front Turn Signal Bulb Replacement, Front Turn Signal Bulb: 6 단계, 이미지 2/3 2002-2008 Dodge Ram 1500 Front Turn Signal Bulb Replacement, Front Turn Signal Bulb: 6 단계, 이미지 3/3
    • Turn the turn signal bulb holder counterclockwise until it stops.
    • Remove the bulb holder.
    • Inspect the bulb. Check for broken filaments or cracked glass.
    • Be sure to replace the turn signal bulb with the correct type for your Dodge. Using an incorrect bulb will result in shortened bulb or fuse lifespan.
결론
To reassemble the headlight assembly, follow these instructions in reverse order.
다른 6명이 해당 안내서를 완성하였습니다.
Michael Saggese
회원 가입일: 10/05/12
1,021 평판
안내서 6개 작성하였습니다
Cal Poly, Team 3-24, Amido Fall 2012 Cal Poly, Team 3-24, Amido Fall 2012 회원
CPSU-AMIDO-F12S3G24
4 회원들
안내서 11개 작성하였습니다
4 댓글
WRONG! Just reach around behind and pop the bulb out. This is A LOT of unnecessary steps for absolutely NO REASON.
Kimberly Parrish-Sanders - 답글
haha…try that on my 2007! Drivers side is impossible to reach. gotta take the whole light fixture.
Randy Drues -
How do you change left side FRONT turn signal bulb on a 2011 CHRYSLER 200
alan burton - 답글
no way you can change my CHRYSLER 2011 200 model this way
alan burton - 답글
댓글 쓰기
조회 통계:
24 시간 전: 6
7일 전: 72
30일 전: 270
전체 시간: 47,647
