주요 콘텐츠로 건너뛰기
2002-2008 Dodge Ram 1500 Fuse Replacement
필요한 것
  1. 2002-2008 Dodge Ram 1500 Fuse Replacement, 2002-2008 Dodge Ram 1500 Fuse Replacement: 1 단계, 이미지 3개 중 1개 2002-2008 Dodge Ram 1500 Fuse Replacement, 2002-2008 Dodge Ram 1500 Fuse Replacement: 1 단계, 이미지 3개 중 2개 2002-2008 Dodge Ram 1500 Fuse Replacement, 2002-2008 Dodge Ram 1500 Fuse Replacement: 1 단계, 이미지 3개 중 3개
    • Open the hood by pulling the hood lever in the driver-side footwell.
    • Reach under the center of the grille and press the hood latch.
  2. 2002-2008 Dodge Ram 1500 Fuse Replacement: 2 단계, 이미지 2개 중 1개 2002-2008 Dodge Ram 1500 Fuse Replacement: 2 단계, 이미지 2개 중 2개
    • Locate the fusebox. The fusebox is the box that says "Fuse and Relay Center", near the left front fender of your Dodge.
    • Unscrew the plastic nut that holds the cover of the fusebox in place.
  3. 2002-2008 Dodge Ram 1500 Fuse Replacement: 3 단계, 이미지 3개 중 1개 2002-2008 Dodge Ram 1500 Fuse Replacement: 3 단계, 이미지 3개 중 2개 2002-2008 Dodge Ram 1500 Fuse Replacement: 3 단계, 이미지 3개 중 3개
    • Remove the nut and the cover of the fusebox. Use the inside of the fusebox cover to determine which fuses you need to check.
    • Locate the fuse grabber. The fuse grabber is located near the front of the fusebox.
    • Remove the fuse grabber from its holder.
  4. 2002-2008 Dodge Ram 1500 Fuse Replacement: 4 단계, 이미지 2개 중 1개 2002-2008 Dodge Ram 1500 Fuse Replacement: 4 단계, 이미지 2개 중 2개
    • Use the fuse grabber to carefully pinch the fuse.
    • Pull the desired fuse out.
    • Be sure to replace each blown fuse with a fuse of the correct current rating and size. Serious damage can occur if the wrong fuse is used.
결론
To replace a fuse, follow these instructions in reverse order. Make sure you buy the correct fuse to replace a blown fuse. Serious damage can occur if you do not use the correct replacement fuses.
다른 14명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Michael Saggese
회원 가입일: 10/05/12
1,129 평판
안내서 6개를 작성함
Cal Poly, Team 3-24, Amido Fall 2012 Cal Poly, Team 3-24, Amido Fall 2012 회원
CPSU-AMIDO-F12S3G24
4 회원들
안내서 14개를 작성함
27가이드 댓글
Thank you for making the instructions simple and to the point!
Sierra W - 답글
not what i was looking for but thank you
eimerben - 답글
I need to find the flasher
Goldie Sandlin -
thanx anyway. but not the answer I wanted. didn't tell me anything about which fuse it was .I looked in the fuse box and didn't c the fuse labled headlight there...
Marc A. Moore - 답글
I'm trying to fine the fuse for the dashlights on a 2008 dodge ram 1500 hemi
Peggy - 답글
댓글 쓰기
조회 통계:
지난 24시간: 55
지난 7일: 344
지난 30일: 1,774
전체 시간: 166,067
