주요 콘텐츠로 건너뛰기
2002-2008 Dodge Ram 1500 Fuse Replacement
필요한 것
  1. 2002-2008 Dodge Ram 1500 Fuse Replacement, 2002-2008 Dodge Ram 1500 Fuse Replacement: 1 단계, 이미지 1/3 2002-2008 Dodge Ram 1500 Fuse Replacement, 2002-2008 Dodge Ram 1500 Fuse Replacement: 1 단계, 이미지 2/3 2002-2008 Dodge Ram 1500 Fuse Replacement, 2002-2008 Dodge Ram 1500 Fuse Replacement: 1 단계, 이미지 3/3
    • Open the hood by pulling the hood lever in the driver-side footwell.
    • Reach under the center of the grille and press the hood latch.
  2. 2002-2008 Dodge Ram 1500 Fuse Replacement: 2 단계, 이미지 1/2 2002-2008 Dodge Ram 1500 Fuse Replacement: 2 단계, 이미지 2/2
    • Locate the fusebox. The fusebox is the box that says "Fuse and Relay Center", near the left front fender of your Dodge.
    • Unscrew the plastic nut that holds the cover of the fusebox in place.
  3. 2002-2008 Dodge Ram 1500 Fuse Replacement: 3 단계, 이미지 1/3 2002-2008 Dodge Ram 1500 Fuse Replacement: 3 단계, 이미지 2/3 2002-2008 Dodge Ram 1500 Fuse Replacement: 3 단계, 이미지 3/3
    • Remove the nut and the cover of the fusebox. Use the inside of the fusebox cover to determine which fuses you need to check.
    • Locate the fuse grabber. The fuse grabber is located near the front of the fusebox.
    • Remove the fuse grabber from its holder.
  4. 2002-2008 Dodge Ram 1500 Fuse Replacement: 4 단계, 이미지 1/2 2002-2008 Dodge Ram 1500 Fuse Replacement: 4 단계, 이미지 2/2
    • Use the fuse grabber to carefully pinch the fuse.
    • Pull the desired fuse out.
    • Be sure to replace each blown fuse with a fuse of the correct current rating and size. Serious damage can occur if the wrong fuse is used.
결론
To replace a fuse, follow these instructions in reverse order. Make sure you buy the correct fuse to replace a blown fuse. Serious damage can occur if you do not use the correct replacement fuses.
다른 11명이 해당 안내서를 완성하였습니다.
Michael Saggese
회원 가입일: 10/05/12
1,021 평판
안내서 6개 작성하였습니다
Cal Poly, Team 3-24, Amido Fall 2012 Cal Poly, Team 3-24, Amido Fall 2012 회원
CPSU-AMIDO-F12S3G24
4 회원들
안내서 11개 작성하였습니다
17 댓글
Thank you for making the instructions simple and to the point!
Sierra W - 답글
not what i was looking for but thank you
eimerben - 답글
thanx anyway. but not the answer I wanted. didn't tell me anything about which fuse it was .I looked in the fuse box and didn't c the fuse labled headlight there...
Marc A. Moore - 답글
I'm trying to fine the fuse for the dashlights on a 2008 dodge ram 1500 hemi
Peggy - 답글
Half of my fuse box only works.Wat could b wrong .I need help
Marco Polo - 답글
댓글 쓰기
조회 통계:
24 시간 전: 67
7일 전: 556
30일 전: 2,610
전체 시간: 114,720
