소개
This is a prerequisite guide to replacing your headlight bulb and turn signal bulb.
부품
부품은 필요하지 않습니다.
Open the hood by pulling the hood lever in the driver-side footwell.
Reach under the center of the grille and press the hood latch.
Use the 10 mm socket wrench to unscrew the first of three 12 mm long 10 mm hex-head screws holding in the headlight assembly. The screw is located just to the left of the headlight assembly.
Unscrew the second screw located approximately 6 inches below the first.
Locate the third screw at the bottom left corner of the headlight assembly just behind the bumper and remove.
Locate the blue headlight wire. Use a flathead screwdriver to pry up one side of the clamping teeth and pull the connector off.
Locate the green turn signal wire clamp. Use a flathead screwdriver to push in the tab on the side and pull off the connector.
Now that all connections between the car and the headlight assembly are disconnected, it is safe to remove the headlight assembly from the truck.
다른 2명이 해당 안내서를 완성하였습니다.
댓글 6개
Don't forget to explain that there is a third bolt hidden behind the wheel frame under a rubber grommet Other than that hidden bolt. I had both headlights out and replaced in 30 mins.
sreilly623 - 답글
yep. found it. with all humbleness i ask, how do i get it? i am not a car guy. sorry. dont revoke man card.
What wrench size for the bolt in the fender?
Kurt Smith - 답글
10mm for all three of them
I have a question are all 3 bolts the same I lost the one that goes underneath the headlight between the bumper will the other two one or the other still work until I can get replacement
lgweaver80 - 답글
