소개
The inside cabin air filter is essential to filtering the outside air of pollutants before it enters the vehicle. It is suggested that the filter be replaced once a year.
Follow the video tutorial by YouTuber NutzAboutBolts to complete the replacement yourself.
필요한 것
동영상 지침
거의 끝나갑니다!
결론
댓글 한 개
only works on 2002, not 2003 thru 2006. They have a completely different plastic mold under the glove box and you cannot get tot he air filter, or whatever filter they replaced the air filter with. I have a 2006 and the video doesn’t work for it. i have read that Cadillac supposedly replaced the air filter with something more perm, but I can see some type of filter thru a small air hole int he plastic. Only way to replace that in any way is to cut thru the plastic, which you would need a dremel
William Novotny - 답글
