주요 콘텐츠로 건너뛰기
2002-2006 Toyota Camry Key Fob Battery Replacement
필요한 것
  1. 2002-2006 Toyota Camry Key Fob Battery Replacement, Key Fob Battery: 1 단계, 이미지 1/2 2002-2006 Toyota Camry Key Fob Battery Replacement, Key Fob Battery: 1 단계, 이미지 2/2
    • Purchase a new lithium coin battery. You can find it at your local hardware store.
    • The battery has a "+" positive side (textured surface) and a "–" negative side (smooth surface).
  2. 2002-2006 Toyota Camry Key Fob Battery Replacement: 2 단계, 이미지 1/1
    • Use your hands or a spudger to separate the key fob into two pieces.
  3. 2002-2006 Toyota Camry Key Fob Battery Replacement: 3 단계, 이미지 1/1
    • Identify which part of the FOB holds the battery.
    • You will not need the other part of the fob until the end.
  4. 2002-2006 Toyota Camry Key Fob Battery Replacement: 4 단계, 이미지 1/2 2002-2006 Toyota Camry Key Fob Battery Replacement: 4 단계, 이미지 2/2
    • Remove the battery from the fob by releasing it from the holder using a spudger or by hand.
    • Be careful that you don't break the contacts when removing the battery.
  5. 2002-2006 Toyota Camry Key Fob Battery Replacement: 5 단계, 이미지 1/1
    • Insert the new battery by pushing it down.
  6. 2002-2006 Toyota Camry Key Fob Battery Replacement: 6 단계, 이미지 1/1
    • Reassemble the fob, using your hands to press the two parts together.
결론
Salman Abu Mazen
회원 가입일: 09/27/21
140 평판
안내서 1개 작성함
UM-Willis-F21S51G7 UM-Willis-F21S51G7 회원
Community
1 회원
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 5
7일 전: 53
30일 전: 225
전체 시간: 5,037
