주요 콘텐츠로 건너뛰기
2002 Nissan Altima Hubcap Replacement
필요한 것
  1. 2002 Nissan Altima Hubcap Replacement, Hubcap: 1 단계, 이미지 1/3 2002 Nissan Altima Hubcap Replacement, Hubcap: 1 단계, 이미지 2/3 2002 Nissan Altima Hubcap Replacement, Hubcap: 1 단계, 이미지 3/3
    • Attach the retention ring to your new hubcap, aligning the divot in the ring with the tire-valve cutout.
    • Be sure to click the ring in each clip around the hubcap.
  2. 2002 Nissan Altima Hubcap Replacement: 2 단계, 이미지 1/1
    • Use a wide tipped removal tool to align the wedge inside the hubcap.
    • You may be able to remove the hubcap with your hands if you grab and pull. Be careful, though, to not injure yourself.
  3. 2002 Nissan Altima Hubcap Replacement: 3 단계, 이미지 1/1
    • Gently push on the solid parts of the hubcap until they pop out of the tire.
  4. 2002 Nissan Altima Hubcap Replacement: 4 단계, 이미지 1/2 2002 Nissan Altima Hubcap Replacement: 4 단계, 이미지 2/2
    • Align the replacement hubcap with the tire valve.
    • There should be a cutout in the hubcap to specifically fit around the tire valve.
  5. 2002 Nissan Altima Hubcap Replacement: 5 단계, 이미지 1/2 2002 Nissan Altima Hubcap Replacement: 5 단계, 이미지 2/2
    • Keeping alignment, hold the center of the hubcap and forcefully push in all the sides of the inner ring until it secures in place.
  6. 2002 Nissan Altima Hubcap Replacement: 6 단계, 이미지 1/1
    • Repeat steps 1-5 for other three tires.
결승점
Bre Sanders
회원 가입일: 04/26/24
133 평판
안내서 1개 작성함
UC Davis, Team 2-6, Whithaus Spring 2024 UC Davis, Team 2-6, Whithaus Spring 2024 회원
UCD-WHITHAUS-S24S2G6
2 회원들
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 10
전체 시간: 38
