주요 콘텐츠로 건너뛰기
2002 Toyota Tacoma Headlight Bulb Replacement
필요한 것
  1. 2002 Toyota Tacoma Headlight Bulb Replacement, Headlight Bulb: 1 단계, 이미지 1/1
    • Pull the lever under the steering wheel.
  2. 2002 Toyota Tacoma Headlight Bulb Replacement: 2 단계, 이미지 1/2 2002 Toyota Tacoma Headlight Bulb Replacement: 2 단계, 이미지 2/2
    • Pull up on the lever under the hood.
    • At the same time, lift the hood of the car.
  3. 2002 Toyota Tacoma Headlight Bulb Replacement: 3 단계, 이미지 1/2 2002 Toyota Tacoma Headlight Bulb Replacement: 3 단계, 이미지 2/2
    • Remove the metal rod.
    • Insert the metal rod to hold the hood in place.
  4. 2002 Toyota Tacoma Headlight Bulb Replacement: 4 단계, 이미지 1/2 2002 Toyota Tacoma Headlight Bulb Replacement: 4 단계, 이미지 2/2
    • Pinch the rubber cover and disconnect the headlight bulb.
  5. 2002 Toyota Tacoma Headlight Bulb Replacement: 5 단계, 이미지 1/1
    • Push down on the metal lever to release it. After you have released the lever you can remove the bulb.
  6. 2002 Toyota Tacoma Headlight Bulb Replacement: 6 단계, 이미지 1/1
    • Remove the headlight bulb cover when you are ready to install it.
    • Do not touch the bulb or let it touch anything to prevent it from getting damaged.
결론
To reassemble your device, follow steps 3-5 in reverse order. At the end of step 3 make sure to push down on the hood to lock it back into place.
다른 한 분이 해당 안내서를 완성하였습니다.
Drake Fenwick
회원 가입일: 02/17/21
133 평판
안내서 1개 작성함
댓글 한 개
thank you, saved me alot of time.
harley cortez - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 22
전체 시간: 1,472
