소개
It is very easy to remove and replace your headlights in your 2002 Toyota Tacoma. You can save a lot of time by replacing the bulb yourself. The replacement is a H4 9003 bulb. The process is easy and requires no tools to get the job done.
필요한 것
To reassemble your device, follow steps 3-5 in reverse order. At the end of step 3 make sure to push down on the hood to lock it back into place.
다른 한 분이 해당 안내서를 완성하였습니다.
