주요 콘텐츠로 건너뛰기
2003-2015 Nissan Armada Cabin Air Filter Replacement
필요한 것
  1. 2003-2015 Nissan Armada Cabin Air Filter Replacement, Cabin Air Filter: 1 단계, 이미지 1/3 2003-2015 Nissan Armada Cabin Air Filter Replacement, Cabin Air Filter: 1 단계, 이미지 2/3 2003-2015 Nissan Armada Cabin Air Filter Replacement, Cabin Air Filter: 1 단계, 이미지 3/3
    • Open the glove box.
    • Use a Phillips #00 to remove the three screws at the top of the glove box.
    • Place your screws aside in a safe spot to use for reassembly.
    • Lift the glove box out.
  2. 2003-2015 Nissan Armada Cabin Air Filter Replacement: 2 단계, 이미지 1/3 2003-2015 Nissan Armada Cabin Air Filter Replacement: 2 단계, 이미지 2/3 2003-2015 Nissan Armada Cabin Air Filter Replacement: 2 단계, 이미지 3/3
    • Use a socket wrench to remove the 8 mm bolt securing the plastic cover to the cabin air filter.
    • Remove the plastic cover and you should see two air filters next to each other.
  3. 2003-2015 Nissan Armada Cabin Air Filter Replacement: 3 단계, 이미지 1/3 2003-2015 Nissan Armada Cabin Air Filter Replacement: 3 단계, 이미지 2/3 2003-2015 Nissan Armada Cabin Air Filter Replacement: 3 단계, 이미지 3/3
    • Carefully remove the filters starting with the left one as its easier to remove.
    • Now remove the one on the right side.
    • If you are struggling, use your fingers to slide it over.
    • Place the dirty air filters to the side and have the new ones ready.
  4. 2003-2015 Nissan Armada Cabin Air Filter Replacement: 4 단계, 이미지 1/3 2003-2015 Nissan Armada Cabin Air Filter Replacement: 4 단계, 이미지 2/3 2003-2015 Nissan Armada Cabin Air Filter Replacement: 4 단계, 이미지 3/3
    • Place the first filter to the right side with the airflow arrows pointing down.
    • Insert the second air filter, to the left of the first filter.
결론
Kenneth Maldonado
회원 가입일: 09/23/23
109 평판
안내서 1개 작성함
Austin Community College, Team 1-8, Watkins Fall 2023 Austin Community College, Team 1-8, Watkins Fall 2023 회원
AUSTINCC-WATKINS-F23S1G8
1 회원
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 4
7일 전: 10
30일 전: 49
전체 시간: 180
