소개
The 1st-generation Pontiac Vibe takes advantage of a dual-filament tail light bulb, which means a single bulb is responsible for both the running tail lights and the brake lights. One or both of the filaments in the bulb can burn out, requiring replacement of the entire bulb.
It’s best to replace both the left and right side bulbs at the same time, even if only one is burned out. This ensures the brightness level of both bulbs are identical. Plus, most replacement bulbs come in pairs of two anyway.
필요한 것
Begin by opening up the rear hatch door by reaching under the "Pontiac" logo and pressing on the rear hatch door button.
Pull on the door from the same location to open the rear hatch.
다른 5명이 해당 안내서를 완성하였습니다.
댓글 2개
How do I replace the 3rd brake light?
What about the 3rd bulb
